Go Back   Rotary Car Club > Vendors and Group Buys > Group Buys
Old 01-04-2015, 01:22 AM   #1
RICE RACING
Don Mega
RICE RACING's Avatar
Exclamation Rice Racing M&W CDI COP Set-up
Here is the superior M&W ignition system with perfect mounting system
Enjoy.
Fits spot on with no load bearing on plugs, all bespoke RICE RACING!
The ULTIMATE!
Bit of background for people, I developed COP systems for the 13B-REW many years ago, field proven, this is one of my old systems below (CDI set up)
RRCOP13BREW-MWCOI-006-VM Vertical mounting
$POA
NOTE: M&W CDI version can run ANY type of M14x1.25 rotary suitable spark plug, from ghetto to don mega
RRCOP-IGN1A-A adaptors for separate supply
$POA *each* so for 13B = $POA[/size]
Originally Posted by almoststockfc View Post
Could you explain what comes in your kit? Bracket, hardware, etc. etc.
NOTE: M&W CDI version comes with bespoke rubber boots and electrical connection springs (x 4)
2 x Coil spacer/mounts
(FRONT and a REAR mount)
1 x Engine bracket/mount
(mounts off center plate)
Fasteners for the mounts x 3 NOTE: M&W CDI version has engine mount and coil mount fasteners only
Instruction sheet, with CAD pictures of fitment, and instructions
Hope to hear from you on email.
NOTES: on ratings and options fully spec'd up system with coils and or CDI boxes etc
Getting asked allot of this on email so best to post here:
[COLOR="DeepSkyBlue"]CDI v's ghetto inductive (all up costs)
NOTE: all systems ratted to run constant duty street or road race applications
CDI RR option 1: 250mJ
M&W coils (x 4) + (Pro Drag 2 CDI box x 2) + RR COP kit
= ~$2800US
The TOP SPEC CUSTOM RICE RACING M&W set up, this comes configured with Hi/Lo switch input into each CDI box
150mJ & 250mJ
These are rated for constant use and NO EXCUSES
Tune the engine, dont let it tune you!
CDI RR option 2: 115mJ
M&W coils (x 4) + (Pro14R CDI box x 1) + RR COP kit
= ~$2100US
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Last edited by RICE RACING; 05-07-2015 at 12:20 AM. Reason: PRICIING UP ON DON MEGA VERSION........ COP you want some ????
Old 01-04-2015, 02:23 PM   #2
Monkman33
Still Building my FD
I was just holding my ign 1a coild and they are weighty. Im not sure I trust that small mounting point to support them. I love the idea. Just would like to see a more robust mounting method.
Uh.... hi.
Old 01-04-2015, 04:35 PM   #3
RICE RACING
Don Mega
Yes when 2 of them are together they are even heavier !
This is why I spend allot of time making my COP system as strong as it is beautiful
Tough, durable, but not stupidly over engineered where it does not need to be..... If there is anything else you want me to clarify I am happy to do so
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-11-2015, 06:12 PM   #4
RICE RACING
Don Mega
Stress and deflection analysis done, see first page
as said its tough as f*ck
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-11-2015, 07:26 PM   #5
RICE RACING
Don Mega
New M&W CDI coil (COI-006) arrived today.
Will design a 13BREW system around these in vertical fitment, these will not need a COP adaptor since its female on the coil end so will design a bespoke spring arrangement with rubber boot, similar to what I did with the Dynatek CDI coils (only similar that its a linear end on end fitment.
IF no COP adaptor will need new coil bracket spacers.
This is a preferred option.
Will NOT be able to 'interchange' these easily.
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-11-2015, 10:26 PM   #6
FC Zach
FC Zach's Avatar
Count me in for one of these! RRCOP13BREW-IGN1A-VM
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 01-12-2015, 07:52 AM   #7
RICE RACING
Don Mega
O.K.
What I will do is when I officially have the PP version in my hand will come back here and 'ACTIVATE' the purchase request, at the moment I am starting the production process of the *-VM version and the COP adaptors as #1 priority.
Some components getting made as this goes up here
Touch wood will have pricing to follow.
Peter
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-12-2015, 03:30 PM   #8
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
+1
'94 Touring - Cursed
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 01-04-2015, 02:28 PM   #9
I suspect the COP Adapter would take up a lot of the load plus there isn't that much torque on them outside of the mounting point.
Old 01-04-2015, 03:20 PM   #10
Monkman33
But the single screw mounting point doesn't look like it would prevent the coils from vibrating. I would rather the cop link would not bear any weight. Since spark plugs dont really like to hold mich weight either.
Uh.... hi.
Old 01-04-2015, 04:06 PM   #11
RICE RACING
Don Mega
Hi MM,
Good point.
Just to clarify.
The mounting bolt very little bending loads, the weight of the coils is supported by the recess in the back of the mount
It mounts against the back of the boss, the COP engine bracket takes all of the loads
To give you an idea of how strong a bolt is, I lift out a whole 13B-REW (130kg) with a single M8 bolt with an eyelet
Either way the design is 'over designed by a safety factor of 100
Short of jacking up the car front the COP brackets you will never ever break them
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-04-2015, 04:08 PM   #12
RICE RACING
Don Mega
Each 'F' and 'R' assembly does not take any weight through the bolt either as they sit on the extension leg from the COP engine bracket, just to clarify
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-04-2015, 03:27 PM   #13
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Count me in..
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 01-04-2015, 04:03 PM   #14
I'm interested as long as it will fit with my current setup, specifically the water injection pump mounted on the frame. I don't remember how much room I have there and I won't be able to measure it for a few more months.
Old 01-04-2015, 04:29 PM   #15
RICE RACING
Don Mega
Forgot to say rotation load is countered by legs of 'F' and 'R' mounting tabs as they are 0.1mm (less) between each other thus the mounting bolts M5x0.8 x 2 are fine and the engine mount is M6x1 x 1 single OEM position.
It's a refined design, I'm totally happy with, each system is guaranteed for LIFE to never ever fail electrically or mechanically in any application, but I will not warrant you lifting out the motor using the COP brackets :P
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
