Old 06-11-2009, 01:24 AM   #1
Rx-7fetish
Blue Blur
Rx-7fetish's Avatar
I believe they are different. If I'm remembering clearly the SE and Vert models came with a 12mm rear bar and the GXL/T2/GTU had the larger 14.5MM rear bar. I want to say you can verify this with the part numbers for factory replacement bushings for the rear...
The part I cant recall is if it changed at all for S4 to S5....
I believe the s4 the turbo is thicker than n/a, and then when they went to s5 both turbo and n/a are the same. Im not sure if they shrank the turbo to the same as the n/a in s5 or if they beefed up the n/a to the same as the turbo. Thats what i remember. I couldnt for the life of me tell you if the numbers so far posted are correct or not but im gonna just nod and agree so i dont look dumb lol
