Rotorhead
car cranks really slow..
well one problem after another on my daily driven 7...
its a 91 n/a FC... it cranks really slow... battery is over 12.4 volts starter is good had it tested at autozone plugs are good, I have spark I have fuel and air of course.. any ideas ? ign switch?
Currently running: 90 GTUs converted to S5 TurboII. Track car. 90 N/A GTUs.. Running project car 89 N/A GTUs in Black #2 10/6/18 Blown coolant seal undergoing rebuild and restomod. |
Rep Power: 20 ![]() |
What's the voltage while cranking?
Do you have a "DVOM" (Digital Voltage/Ohm Meter) available to diagnose your problem?
Get a Haynes Manual for the RX-7, as well as take a look at buying a Factory Service manual, if this is your daily driver, the book will SAVE you money in the long run, so it's a heck on an investment. I think Racing Beat might still have a paper version in stock, or if you could just go here: http://www.rx7city.com/techconnect.htm PS: Even with quite a few knowledgeable people on here, it's still better to look at the factory service manual first to avoid wasting time on simple problems.
Rotaries:They are NOT that complicated! Last edited by Max777; 04-17-2009 at 11:10 AM. |
Voltage Drop test. It could be anything from a weak battery, to a bad voltage drop across the starter (and everything in between). Break out your Voltmeter and start testing.
Rep Power: 21 ![]() |
what kind of battery. hold old is said battery. what is the CCA rating?
Rotary since 1972
Rep Power: 17 ![]() |
Get the book and DVOM.
Check battery connections and all grounds. If good test battery. |
yeah check the resistance on the wires going to the starter, perhaps try to clean them where they attatch to the starter as well.
Blue Blur
#9 |
Rotorhead
hey ya'll i pulled the plug on my car for a while... i figured if its going to be down I'll get the injectors cleaned.. so i'll post an update bout when i put things back together...
#10 |
Rotorhead
Hey ya'll this is something that i figured out last night.... its highly possible that the plugs i put in a san jose. Fouled up on the trailing side, the plugs i pulled on the trail side of both rotors had oil and ash or (carbon?) on them when i pulled them... i tested all the plugs and the trailing had weak spark. compared to the leading which had stronger spark.. speaking from visually seeing the spark itself.
Do you think that what happened? I redid some grounds and added some too..
#11 |
Rotorhead
Cold cranking amp 640. Do you think I need something higher?
#12 |
Volts != amps.
#13 |
Rotorhead
thanks but everytime i crank the car over and over it sounds like it getting slower, i rechanged that same battery over 2 hrs ago and it still cranks really slow... its not my grounds, I cleaned them and checked them too, even added a few. any recommondations on a new battery ? brand ? cranking amps? price ? etc
#14 |
Gear Head
[QUOTE=Rotary#10;82910]well one problem after another on my daily driven 7...
its a 91 n/a FC... it cranks really slow... battery is over 12.4 volts starter is good had it tested at autozone plugs are good, I have spark I have fuel and air of course.. any ideas ? ign switch?[/QUOtE Last edited by mazda master tech; 05-07-2009 at 09:36 PM. Reason: woops |
#15 |
Gear Head
Look at your cables or manual trans could be your throw out bearing
