Old 03-18-2008, 11:05 AM   #1
RXtacy
RXtacy's Avatar
Originally Posted by ObliqueFD View Post
Isn't back pressure a bad thing on turbocharged cars?
In general yes, but if you have your boost at a set value with a given back pressure and all of a sudden that back pressure goes away... Well you overboost like crazy and your motor will probably not be in great shape afterwards.
93 Frozen Grey Metallic FD
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 03-18-2008, 12:02 PM   #2
busted7
busted7 is on a distinguished road
To add the the above comment: You would need to tune for open cut out and also closed cut out. I guess it could be done but the only reason i can imagin would be if your in a state were you have to maintain stock exhaust but want performance at the switch. If you state your goals it would help!
busted7 is offline   Reply With Quote
Old 08-05-2011, 04:01 PM   #3
Signal 2
Viable Fossil
Signal 2's Avatar
Originally Posted by busted7 View Post
....the only reason i can imagin would be if your in a state were you have to maintain stock exhaust but want performance at the switch....
^Agreed. Regardless, anyone comtemplating should understand that many States...probably most, have statutes outlawing exhaust cut-outs. In my State they aren't widely enforced anymore, especially with the Hot-rod's growth in popularity the last few years. But the statute is still there. And if a State has visual inspection, a cut-out is hard to hide.
Jim
VR R1 FD
