				Rep Power: 22 ![]()  |
			If you are going emission delete........you basically block EVERYTHING except for a select few.
			-Leave the large port on the backside of the TB for the Oil Injector Vacuum spider (unless you are pre-mixing, then cap it) -Leave the large port for the brake booster -Leave the port on the turbo side of the UIM (pictured above) for boost reference -Leave the port for the Fuel Pressure regulator. Everything else is capped off. That is really all you should have if you are emission free.
	1976 Mazda Cosmo RX-5 1976 Mazda Cosmo RX-5 2003 Toyota Tundra TRD 2015 Toyota 4Runner SR5  |
		#2 | |
				Rep Power: 17 ![]()  |
		![]() Quote:
   can i call you or you call me 239-281-9768 michael
