Old 03-24-2009, 12:10 PM   #1
The ports on your block look really great now! Nice build!
I'll keep my fingers crossed for you on a sure first-start attempt!
Old 03-24-2009, 12:26 PM   #2
Sounds like your engine adventures went a lot smoother than mine. I'm trying to figure out if I want to buy a pressure tester or build one from lowes/homedepot. For some reason I have 1 inner coolant o-ring left over. It's causing me to second guess my work so I'm going to pressure test the coolant passages to see if I did remember to install all the o-rings or if I just screwed up somewhere and forgot one o-ring. Honestly I don't think I screwed up but it's causing me enough doubt that I want to make sure. The funny thing is, I installed all the Outer rings--so I can't think of any reason why I would suddenly skip installing an inner ring since I do them both at the same time (outer and inner).
Ouch, sorry man. I hate to say it but I wouldn't chance it, I'd pull it apart. You're talking about the gas seals right? The orange ones? If you know you started with the right amount, I wouldn't waste the time with a tester. It may hold during the test but once combustion pressures start, I doubt vaseline and holymar will hold it. I'd just be safe and crack the thing open.
Thanks. I'm satisfied with the intakes, and really happy with my exhaust ports. I haven't needed to port anything in years so I practiced on a pair of junk housings. Like riding a bike though, by the time I got to the one pictured, it was my third attempt.
Old 03-24-2009, 02:18 PM   #3
That's the thing. I'm not sure if it's an extra one or not. I know if it is not an extra one then it's one that should have gone on the intermediate housing since that's the only one I can't vividly recall. I'll go ahead and break it apart just to make sure I have it all together. *Sigh*
