Old 03-24-2009, 10:59 AM   #1
Sounds like your engine adventures went a lot smoother than mine. I'm trying to figure out if I want to buy a pressure tester or build one from lowes/homedepot. For some reason I have 1 inner coolant o-ring left over. It's causing me to second guess my work so I'm going to pressure test the coolant passages to see if I did remember to install all the o-rings or if I just screwed up somewhere and forgot one o-ring. Honestly I don't think I screwed up but it's causing me enough doubt that I want to make sure. The funny thing is, I installed all the Outer rings--so I can't think of any reason why I would suddenly skip installing an inner ring since I do them both at the same time (outer and inner).
