| Unique Rotary Classified Anything from 20B, 13B-RE, Rare Rotary Related Items... |
#16 |
The one in the Cosmo now is a D.
08 Anniversary RX-8,93 RX-7,90 Cosmo(20B) |
#17 |
As the engine is "503" with no letter, it is an original run engine and as such, is the least desirable of them all due to problems Mazda had with these engines failing. The problem is with the irons and these were redesigned in the B series and greater engines. FYI - I have C339 which makes me happy. From the "other" forum:
I do not know the total numbers of "runs" that were made but it goes like this: the first run went from 001 to 999 then the next run was A 001 to A 999 there may have been more than 1000 per run but this is what I have seen. next came: B 001 to B 999 then last was: C 001 to C 999 (actually D was the last series) the differences between the run numbers are strength. the first 2000 motors were the first run and are the ones that mazda had the problems with, and had changed lots out on warranty to the newer motors at great expense. I was told that the first run motors have a short life and its not a matter if they will fail, rather when, especially under higher boost levels (anything over 12psi) the strengthened housings of te 2nd run (B toC) make the motor much more reliable and hold higher boost. |
#18 |
Rep Power: 10 ![]() ![]() |
I thought it started from C series not B (stronger engine).. But its been awhile. I have a number and a "D" series engine.
Also to add, There are few "E" series. Some say this was the last series Mazda made and used mainly as a replacement engines for Eunos Cosmos. I have seen only one photo of E series engine.
#19 |
I'm learning a lot!
#20 | |
#21 |
Thanks for the info guys.
#22 |
After hearing the bad news, damn. I was kinda interested too, being in LA not too far from you and about to get my reenlistment bonus =(
#23 | |
It has the counterweight still attached!!!!
08 Anniversary RX-8,93 RX-7,90 Cosmo(20B) Last edited by BlueflameFE; 03-08-2009 at 04:30 PM. |
#24 |
Now listed on ebay:
http://cgi.ebay.com/ebaymotors/ws/eB...m=140315249097
#25 |
whats the reserve?
or whats the lowest you will take for it? locally |
#26 |
Sold
#27 |
May I ask what it went for? It was an original series engine right?
#28 |
...paying to play?
Holy jesus! I think I see that it sold for $750.00!!! WTF plz don't tell me it was that low
![]() ~Shar |
#29 |
I am sure it went for more than that. He ended the eBay bidding because it looks like he sold it elsewhere.
