Show your rotary car build up. Show off your Rotary Car build! |
#1 | |
IT'S ALIVE!
I want to do DGRR so badly but it's very unlikely this'll be done in time. I'm getting all the wiring done now and assuming everything works I'll still need to setup the display and tune the car before it's driving. Anyone wanna help? |
#2 | |
Professional Stick Poker
#3 | ||
Rep Power: 10 ![]() |
MAP based or Alpha-N? What ECU? ![]() Quote:
Rep Power: 22 ![]() |
#5 | |
Temporarily insane.
For my collection of short stories: Kindle Nook |
#6 | |
IT'S ALIVE!
I have no turbo so it's the only way to go.
I'm hoping it'll drive well enough for what it is and not be an on/off switch at 8000 RPM. Comfort-wise, it's basically a track car: no A/C, no heat, no radio, no P/S, next-to-no insulation, solid engine and transmission mounts, etc. Last edited by infernosg; 03-01-2017 at 12:19 PM. |
#7 | |
Duh
![]() So instead of adding turbo, add lightness? Why not both? ![]() Quote:
Spec's on the internals?
#8 | |
IT'S ALIVE!
Money?
Is there some way to utilize the MAP just for fuel correction for like altitude and ambient conditions? Like not load-based tuning but just simple corrections? The TPS is a Haltech (GM?) three wire unit. S5 non-turbo rotors, RX-8 e-shaft and gears, S4 TII irons, S5 TII housings, and OEM Mazda seals (upgraded to FD corner seal springs) except NRS ceramic apex seals. It's got a large street port from Defined Autoworks geared more toward top-end power. Racing Beat pulley up front and their aluminum flywheel out back and everything's been balanced by Mazdatrix. |
#9 | |||
![]() ![]() Quote:
The sensor should be ok, my concern would be the linkages and the instal. The projay and rotary works TB are notorious for having too much slop and they just turn out to be a fucking nightmare to tune. Almost as bad as a microwrech and their whole strategy using the TPS to bounce between maps for crank, idle, and cruise. Quote:
Bookmarks |
