Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > ZN Performance
ZN Performance (OH) www.znperformance.com RX7 and RX8's performance and parts. 3488 Millikin Court Columbus Ohio 43228 614-264-9588
Old 11-04-2016, 09:39 AM   #1
zayrx7
zayrx7 is on a distinguished road
BorgWarner S400
Lots of torque on this monster
FC with S5 block stud
1000cc/2000cc
1/2 bridge
E85
borgwarner S400 turbo
File Type: jpg 14102255_1292253507498720_8769072781852239487_n.jpg (89.3 KB, 16 views)
zayrx7 is offline   Reply With Quote
Old 11-04-2016, 10:11 AM   #2
hades
1000cc/2000cc
1/2 bridge
E85
It looks like Helen Keller was trying to draw line and failed miserably
This is going to tear
Old 11-04-2016, 10:18 AM   #3
Wonder what the problem is? Ignition breakup is clear, loosing the tach signal, way to lean... running 12's with that much boost won't last long unless the dyno wasn't calibrated properly
Then again I saw your comments on the evil forum about timing and I lol'ed
Old 11-04-2016, 10:28 AM   #4
zayrx7
Oh! My this forum is so negative, the car was slipping on the dyno and the A/f are tuned too 11.5-11.8 timing is set to 9 degrees up top and yes it was loosing tach signal, also this was tuned on E85.
Old 11-04-2016, 10:30 AM   #5
zayrx7
It's called loosing tach signal and slipping on the dyno
Old 11-04-2016, 10:38 AM   #6
hades
It's called not posting worthless info.
Old 11-04-2016, 10:40 AM   #7
hades
Then fucking say that when you post. And what is the plan to fix the issues.
Holy fuck man. It's not being negative - it's elavulating the half ass shit you post.
Old 11-04-2016, 10:45 AM   #8
zayrx7
The post was about the dyn #
Old 11-04-2016, 10:53 AM   #9
zayrx7
graph
Old 11-04-2016, 10:54 AM   #10
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
You confuse negativity with being critical. You typically present piles of shit, yet expect praise.
If you only see criticism as negativity, instead of an opportunity to better your products, then we will continue to criticize what you post.
Bottom line, you lack the skills to support the ego you display.
'94 Touring - Cursed
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 11-04-2016, 11:01 AM   #11
zayrx7
So cursing someone out isn't negative
Old 11-04-2016, 11:17 AM   #12
Loosing tach signal and slipping on the dyno will not drop a 1/2 point of AFR unless the load drops as well. This is why tuning with bullshit ecu's with no or lacking datalogging is such a ridiculous pain in the ass.
Old 11-04-2016, 11:18 AM   #13
Also not seeing anyone cursing you out. Just seeing crap getting posted and people voicing opinions.
Old 11-04-2016, 11:22 AM   #14
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
You must be a very tender, unique, delicate little blossom of kindness and hope if you think an ENGINEER using adult language to describe the trash you post up is considered "cursing someone out".
Here's a hint: It isn't. Grow a set and/or (preferably "and") go away.
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 11-04-2016, 12:26 PM   #15
hades
I post data to High level executives.
I explain details of the graph and any parts of the graph that don't make sense.
Just posting up information is useless. It's not inspiring. It's a waste of time.
