Rep Power: 21 ![]() |
So im stuck at work. TII cranks, no tach. no firing.
did the coil just go bad? but even with that would one or the other get the engine
Rep Power: 20 ![]() |
Have you checked the fuses?
Well that's a load of shit. His car would still start with a dead TPS and it has nothing to do with the tach.
#4 | |
main relay still intact?
im worried that its in the harness. car started fine after i played around with a few connections....
it did this earlier this week as well but started, just had no tach. Then when you were going over 5 mph it has a two beep repeating noise going on the entire time you were driving...
#6 | |
then how did it know i was stopped?
Electronic speed sensor in the speedometer.
#9 |
crash auto?fix auto
To me it almost sounds like a crank sensor issue.
I'd check the wiring over and make sure there's no loose connections. Pay clsoe attention to the exposed wires where they enter the rubber grommet in the CAS, I've seen a few as of late with broken insulation there. No crank signal would certainly mean no start. If the trailing coil was burnt, you'd have no tach, but it should still run it would just be a little sluggish and down on power. Although its a possibility, so you could swap another on since its simple and would rule out one option. |
#10 | ||
