Old 04-06-2016, 03:23 AM   #1
"BEST" requires:
1) Aftermarket bumper (or mod stock front bumper) for larger holes in bottom corners
2) 2 oil coolers - left and right
3) Required plumbing to make it all work
Old 04-06-2016, 07:17 AM   #2
Pete_89T2
Pete_89T2's Avatar
Assuming you're happy with your current water & intake air temps on the V-mount setup, and you don't want to change any of that, I think Ted's idea to switch to dual oil coolers in each lower corner, with the proper air ducting via new/modified bumper to deal with oil temps makes the most sense.
The oil line plumbing for that may be a PITA, and then the next question would be is it better to plumb the dual oil coolers in series or parallel?
Old 04-06-2016, 08:30 AM   #3
hybrid G
hybrid G is on a distinguished road
water temps are awesome too cool at times actually
hybrid G is offline   Reply With Quote
Old 04-06-2016, 08:29 AM   #4
hybrid G
You are correct here, its truly the best way, true tried and tested.
But I want to work with what I have now..... no track days this yr.
low on $$$
"BEST" requires:
Old 04-06-2016, 12:18 PM   #5
low on $$$
The car is not supposed to be getting that hot (on oil temps) on the street...
Aftermarket oil temp gauge?
Can you verify the temps?
If your oil temps are indeed overheating on the street, something else is drastically wrong...
Do you still have an oil thermostat on the system like stock?
The stock oil cooler should have no problem dealing with anything you throw at it on the street, unless you don't drive under 4kRPM's...
