#16 | |
Rep Power: 20 ![]() |
#17 | |
What is indeniable is the fact that drilling removes metal. Removing metal lowers heat capacity. So you have the same amount of heat going into less metal. This just concentrates the heat more. This is how heat risers and cracking develops easier. If you want to pay for cross-drilled brake rotors, go right ahead. It's your money. -Ted |
#18 |
I think I'm just going to go with blanks.
#19 |
I went with the Beck Arnley's. I hope they work out because they only have a 90 day warranty, compared to the 2 year on the Duralasts.
#20 |
destroy, rebuild, repeat
i got the slotted rotors from rx7store.. i cant tell much difference from stock, but im still breaking them in, so no really hard braking yet
#21 |
There's a need to break in slotted rotors?
#22 |
You need to break in any new brake rotors and / or brake pads.
-Ted |
#23 | |
Rep Power: 21 ![]() |
just seat them though, right? Get up to speed (25mph) and brake fairly hard to get them seated. Or is there another procedure that's more appropriate?
#24 | |
In my case, I'll be putting on a new set of Hawk HPS' and new calipers along with the new rotors. Edit: I found this: http://shielsmasonry.com/Beddingpadsandrotors.pdf . It would seem that I could break in the rotors and pads at the same doing what the I put in parentheses above (After installing new pads make 6 to 10 stops from approximately 35 mph with moderate pressure. Make an additional two to three hard stops from approximately 40 to 45 mph)
1986 Sport: 132k miles, 5A (Sapphire Blue Metallic), Tokico Blues, Racing Beat Springs, Custom LED tailights (only S4 LED tails in the world), SSR Mark II, Racing Beat exhaust, S5 black interior, Rotary Resurrection rebuild at 120k miles Community Service Manual RotorWiki "Imagination costs nothing; we could build square locomotives or fly to Mars" - Felix Wankel Yesterday is history, tomorrow is a mystery, but today is a gift. That is why it is called the "present." Last edited by My5ABaby; 07-02-2008 at 03:36 PM. |
#25 |
My break-in procedure...
Moderate stops from freeway speed - i.e. ~60mph x3 Heavy stops from higher speeds - i.e. ~100mph x3 Let the brakes cool down thoroughly after doing this. Of course, all the usual disclaimers apply... -Ted |
#26 |
Is this for new pads and rotors?
#27 |
I've read somewhere that you should not be doing with new pads + rotors.
Either use used pads on new rotors or vice versa - new pads on used rotors. I try not to use new + new. I think my above break-in is from Hawk? Or was it Wilwood... :P Excuse the poor memory... ![]() -Ted |
#28 | |
Anyone else have input on this?
#29 |
Hawk break-in procedure for "racing" applications:
http://www.hawkperformance.com/motorsports/faqs.php#Q5 Wilwood "bedding" procedure: http://brakepads.wilwood.com/03-tech/index.html -Ted |
