Tires,Wheels,Suspension,Brakes Info about Tires, Wheels, Suspensions, Brakes, etc. |
#1 | |
The FC doesn't like going that low without running into major camber problems, especially in the rear. An (upright) rear camber adjust rod will only take out so much (negative) camber in the rear. Even with the adjustable links on the front of the rear subframe, you end up smacking the whole thing on compression. Pete_89T2's pic looks like it has a smidgen too much camber in the rear, or it's a weird illusion of the pic due to the compression of the suspension due to the turn... You'd get away with about 2 - 3 "fingers" of gap in the rear before there is really too much (negative) camber. Remember, rear camber hurts your straight-line acceleration due to inefficient contact patch of the rear tires (upon acceleration). It also causes uneven tire wear back there. Fronts are no problem due to almost any off-the-shelf front camber plates can dial it all out. It's still a bit problem in the rear on really drastic drops... -Ted |
#2 | |
Can't.Make.Up.My.Mind.
'90 GTUs Stay up to date with my photography '06 Toyota Highlander Hybrid '10 Toyota Prius "Initial Success or Total Failure" Last edited by project86; 01-28-2015 at 12:17 PM. |
#3 | ||
Rep Power: 17 ![]() |
Thats why mine was so low short stroke coilers and I had AWR eerything in the arse lateral links spherical bearings etc.
^I noticed that in the picture too, and wondered why it looked that way. I always assumed it's just the lateral-G loading combined with the wavy road surface crowning. The RB springs I have are supposed to lower the car about 3/4", but when I measured the difference (from subframe rails to my garage floor), the difference was only about 1/4" lower than with my stock springs & shocks. Granted, the stock springs were likely worn out and sagging when I replaced them.
#5 | ||
Haha the dreaded worn out spension lift when replaced.... ![]()
Bookmarks |
