#91 |
Don Mega
It's hard for people to see as they don't have the CAD detail but these coils have a flat shoulder near the mounting tabs, if you pay close attention you will see all 4 ends on the coil spacers are different lengths to makes sure the butt up against these flat shoulders, so when a bolt is installed the coil cannot drop down or up or rotate at all, its not physically possible, thus the second mounting tab is redundant.
The GOLD coil spacers are so strong that to deflect them would need over 100kg of force and then the movement is minimal. You could add (LOL I COULD!) in another middle mount in the coil spacers but would be not needed and just make it heavier and more complex, then it would need specialist cutting of both coils and you could not run two M7 bolts next to each other like that as there is no wall to thread both, let alone the head for the fastener and it would look stupid and serve no real purpose except for being along for the ride, thus I designed it as it is. And its solid, cant move anywhere. p.s. Th gold legs lost the feature on the bottom of the locking I describe, you see it in the silver versions! Should fit the stock set up now with ease. ETA dunno, hopefully soon once I see how many people want them?
www.riceracing.com.au Worlds best Apex Seals Coil on Plug Water Injection ECU Calibration Last edited by RICE RACING; 01-08-2015 at 09:43 AM. Reason: clarification |
#92 |
Get off my lawn!!!
Rep Power: 15 ![]() |
Awesome! Well, count me in for a set of mounts/COP adapters
![]() (Though, if there will be color anodizing/coating options I'd rather have a gloss or flat black as opposed to gold hehe)
'94 Touring - Cursed '96 NA Miata '14 Mazda3 Hatch '14 Aprilia RSV4 R |
#93 |
Don Mega
This is what it will look like, not rounded like the GOLD one, I was just fucking around with it. too hard to make like that too much machining
![]() In these pics you can see the shoulder thing I was describing on each coil making them impossible to move once bolted by a single tab. OFF to be another fucking 2am day!
#94 |
^ Just a thought, what is the approximate distance from the housing is the back of the coil including the plug socket? For us LHD people is there a possibility of interference with the steering shaft?
#95 |
Waffles - hmmm good
This is very cool. Would this fit 12A spacing by just twisting the COP adapters a bit or does
the bracket need to be modified to do that? I suspect the twisting the adaptors won't line up with the plugs well. Whats the ballpark $$ on this? We talking 100s or 1000s of dollars? Plus shipping of course.
#96 | |
Rep Power: 10 ![]() |
Thanks Peter!
#97 | |
Don Mega
If I were Adobe I should charge around $20,000 for this ![]() But seriously I hope it to be in 100's range rather than 1000's cause otherwise I myself will run high tension leads or rip it all out and put in a boat anchor engine haha.On the 12A front: * COP Adaptors are universal (fit anything) ![]() * Engine bracket needs redesign per engine * Coil spacer brackets need adjustment to suit spark plug spacing in X & Y dimensions ![]() Would have to design an engine bracket mount that uses the bottom large hole in the center plate ![]() Best to put a 13B-REW in it ![]()
#98 | |
Don Mega
#99 |
Don Mega
Have designed some little 'limit locks' that go under the cover plates, these lock the stroke of the spring, and can be placed by the customer to lock the COP adaptor to the coils or to the plugs (axial movement with range of groove/slot) when taking shit on and off...... idea is to lock it to the coil though.
#100 | |
![]() Quote:
#101 |
Don Mega
I tidied up the design of V3, this is the latest spec with rounded brackets, and showing the boss detail to lock in the coils with single bolt, fixed holes M7x1 threaded for coil mounting and M5 hole to Engine bracket mount.
I think it looks good ? ![]() ![]() ![]()
#102 |
Don Mega
Couple of high quality images for you to beat off too....
www.riceracing.com.au Worlds best Apex Seals Coil on Plug Water Injection ECU Calibration Last edited by RICE RACING; 01-08-2015 at 06:40 PM. |
#103 |
Don Mega
Little video..............
#104 |
Don Mega
Another small revision to the coil spacers, cosmetic mostly larger radi in the coil section (fill it out) and transition to the center bracket.
This maybe the 'expensive version' versus the one that can essentially be fabricated! (flatter versions), it just depends on if people want a work of art or are cost focused ![]() ![]()
www.riceracing.com.au Worlds best Apex Seals Coil on Plug Water Injection ECU Calibration Last edited by RICE RACING; 01-08-2015 at 07:49 PM. |
#105 |
I do.
![]() I'll talk to ya later
____________________________________________ 1976 Cosmo needing lots of work 1993 Rx-7 410 RWHP single turbo toy 1985 Rx-7 toy/project car 411HP stoplight terror 2001 Dodge ram 4wd.parts hauler 2016 Ram 2500 cause its a hemi 2006 VW TDI commuter __________________________________________ I guarantee there's a pregnant redneck teenager somewhere in a shitty trailer park that thinks "Ebola would be a lovely name for their child"...
