Old 08-19-2013, 03:54 PM   #18
Actually looks like a good job!
Yeah, I think you're getting a little paranoid about the mold release...
We went with the minimum 2 - 3 coats of wax and then a layer of PVA.
The release went OK.
I don't think you should have any problems.
Bubbles are due to the complex shape, so either cut the fiberglass mat smaller (not in your case) or use thinner, lighter weight mat - which would be the better option here and just run more layers.
Experience will tell you what you can and cannot get away with.
It comes down to getting corners and nooks / crannies to transition as smoothly as possible.
RETed is offline
