#11 | |
IT'S ALIVE!
![]() I wasn't able to get good measurements of the groove myself so I left them the stock stationary gear to use as a setup. The groove is approximately .100" wide by .060" deep. I plan on using a little RTV in addition to the o-ring so a little error shouldn't be that big of a deal. I also picked up the input shaft. Fortunately it looks like the turned out correctly. Modified Miata input shaft on bottom, stock RX-7 on top: ![]() A quick check shows the overall length and spline length to be a little longer than the RX-7 shaft but I verified the dimensions with Mazdatrix's recommendations and I trust they know what they're doing so everything should work. The fiberglass body parts were delivered yesterday too (busy day). Shine Auto vented hood: ![]() The hood is latched in above picture but not bolted to the car. It lines up fairly well but I'm going to have to lower the latch quite a bit it seems. I'll be picking up some hood pins somewhere along the way. It's a true vented hood: ![]() I'll be tying the vent into some kind of post-radiator fan ducting eventually. Shine Auto Fenders: ![]() It's a pretty subtle flare but should be enough to cover the wider wheels and tires: ![]() I've got family visiting this weekend so I won't be able to work on the car too much. The immediate plans are to reassemble the transmission and to mock up the body parts to verify fitment. I'll leave the final fitting and painting to the professionals. I'll be picking up a fender roller early next week to work on the rears. |
