Closed Thread
Old 03-08-2013, 09:16 AM   #1
FC Zach
FC Zach's Avatar
I wouldn't fret about the harmonic balancer being on the original transmission and not the Miata, I believe only S5 transmissions got those. The bearing looks fine to me.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
FC Zach is offline
Old 03-11-2013, 08:29 AM   #2
infernosg
IT'S ALIVE!
infernosg's Avatar
Originally Posted by N.RotaryTech View Post
Interesting build.
I like that wiring. Clean.
Thanks! It's far from perfect and nowhere near as nice as some of the other builds going on right now but it should serve its purpose. I figure I'll probably redo everything in future so I'll spend the big bucks on fancy loom and connectors then.
There's a little more wear evident now that I've cleaned the tail housing some but I plan on just leaving it. I really don't want to mess with removing that and installing a new one.
I spent a good amount of time in the garage this weekend and got seemingly nothing done. I was finally able to remove the large lock-nut, which holds the harmonic balancer, with some large channel-lock pliers and a vice.
After that I removed the selector rods ends and pulled both intermediate housings.
That's as far as I can go now without the tools needed for further disassembly. I spent the rest of my time trying to clean 24 years worth of oil residue and road grime from the transmission housings.
I also picked up the 929 brake booster and master cylinder. I don't remember the booster being this rusty when I looked at it last week.
The inside of the booster and backside of the MC were both completely dry so I assume the leak is from the bottle. Does anyone know if the seals for the 929 bottle are the same as those for the RX-7? I took a wire brush on an angle grinder to the booster and forunately it's only surface rust.
It's pretty pitted but still structurally sound. I need to pick up another wire wheel to remove the paint from the backside then I plan on hitting the whole thing with several layers of hot temperature primer, paint, and clear. The MC cleaned up pretty decently with some solvent and a wire brush.
infernosg is offline
Closed Thread
