#40 |
No I scrapped that idea. Since the adjustable check valve has a spring that restricts the flow the water pressure would be reduced by whatever amount it was set to. That would not only reduce my total water flow but also reduce the atomization. If the valve was set to 8 psi and Im running 28 psi of boost pressure my effective water pressure would then only be 20 psi.
500+ HP thanks to: ![]() Fast reacting IAT sensor thread! Mechanical Pre-turbo Water Injection Thread Dual Stock fuel pumps Thread T2 differential swap! |
