Old 08-13-2012, 08:34 AM   #1
Garfinkles Motor Works
If it is not a tight fit then it will leak .Put the banjo fitting in the motor with a hose to the new part fitted with AN or JIC fittings .I would mount the part away from the motor so it will not pick up the motors heat .You should be able to find a way to modify the banjo fitting to attach a hose that will work with the AN or JIC fittings .
