|  05-07-2012, 07:10 AM | #1 |
| The Newbie Join Date: May 2010
				Rep Power: 0  |
				Help me choose apex seals and bearings
			Hi guys. I'm looking to build a new engine for higher power output with a goal of 400HP on pump gas. This will be a daily driven engine, it may see an autocross one day but not often. The parts I need help with are Apex Seals: I've looked at 2 piece Mazda, Goopy and ALS. The Mazda have proven wear characteristics. The Goopy and ALS are regarded as great for high power applications and resistance to detonation events. Does anyone have any feedback on Goopy or ALS seal housing wear characteristics? Stationary and Rotor bearings: The engine I'm rebuilding has excellent condition stock bearings but I'm unsure how they will hold up in the long run at elevated power levels. Either way I will be using a Racing Beat high pressure regulator and machining a groove for an o-ring between the pump body and front iron. I'll be keeping the stock ball and spring eshaft jet as well. Additionally I (need help with) was thinking RX-8 gears/bearings and Mazdatrix competition rotor bearings along with reaming the oil passages to 3/8". Plan is to keep the redline the same. Thoughts on whether is a worthwhile mod or waste of money? Appreciate an feedback you guys can give. |
|  05-07-2012, 04:21 PM | #2 |
| Rotary Fanatic Join Date: May 2010
				Rep Power: 16  |
			Sounds like a good list with the except the reaming of the passages to 3/8", not to say it will be detrimental, just haven't heard that mentioned in any of the oil mod conversations.  I'm running the Goopy seals with 9.4 rotors personally, my plan is to run around 300whp daily (low boost) and 350whp (highboost) for ....fun stuff after the engine is broken in. No the only internal mods I've done is the modify the oil pressure regulator for 80psi. |
|  05-09-2012, 07:02 AM | #3 |
| The Newbie Join Date: Jan 2010
				Rep Power: 0  |
			I'm not sure about Groopy and ALS but Mazda seems fine for your Applications. No Apex seal can survive too much ping, Groopy might wrap instead of breaking like Mazda, but the result is the same --- you lose compression and you need a rebuild. but if your tuning is safe you don't have to worry too much about that in the first place, all you really need to focus on is the tuning. You can use 13B-MSP Eshaft and Bearings, they're better and cheaper. no modification is necessary. As for Rotor bearings, you don't need the compeition one unless you are going above 8-9K rpm all the time, stock actually works quite well for oil pressure, you can just use FD rear and add 2 1/8" shims to the front, then you are set, and much cheaper |
|  05-09-2012, 10:47 AM | #4 | |
| IT'S ALIVE! Join Date: Dec 2009 Location: Richmond, VA
				Rep Power: 16  | Quote:
 A note on the RX-8 stationary gears: some modification is required for the rear gear to ensure the oil passage is open and you'll need to use hylomar/silicone to seal the rear gear to the housing as there is no o-ring groove. Last edited by infernosg; 05-09-2012 at 11:18 AM. Reason: oops | |
|  05-09-2012, 11:29 AM | #5 | ||||||||||||
| Test Whore - Admin Join Date: Mar 2008 Location: Right Behind you son
				Rep Power: 10  | Quote:
  Ditch that, get a plug. Quote:
 Not to mention... I would much rather have a seal warp and loose compression than break and wipe out a rotor, a housing, possibly a plate and possibly a turbo.... so no, the results are not the same Quote:
 -Brian @ S1
				__________________ -The Angry Stig- DGRR 2009, 2011, 2012 & 2013 - Best FC DEALS GAP!! WOOHOOOO!!!!! 2015 Audi S4 - Samantha - Zero Brap S4 2004 RX8 - Jocelyn - 196rwhp, 19mpg fuel to noise converter 2000 Jeep Cherokee Sport - Wifey mobile - Now with 2.5" OME lift and 30" BFG AT KO's! So it begins 1998 Jeep Cherokee - 5 spd, 4" lift, 33" BFG's - Rotary Tow Vehicle 1988 'Vert - In progress 1988 FC Coupe - Gretchen -The attention whore BEAST! I'm a sick individual, what's wrong with you? I'm pure Evil I'm still insane, in the best possible way. I think Brian's idea of romance is using lube. Your rage caused the meteor strike in Russia. The Antichrist would be proud of his minion. You win with your thread. Most everything It's a truck with a steel gate on the back. Just a statement of fact Motec M820, AIM dash, ported 13B-RE Cosmo, 6-spd trans, 4.3 Torsen, custom twin wg fully divided mani, Custom 4" split into 2x 3" exhaust, Custom HMIC, Custom custom custom custom I like to welder stuff.... No Bolt-ons allowed. Dyno'ed @ Speed1 Tuned by me - 405rwhp on WG.... WM50 cuming soon. -Angry Motherf*cker Mode ENGAGED- | ||||||||||||
|  05-09-2012, 12:08 PM | #6 | |
| 400WHP or bust Join Date: Mar 2008 Location: Kincardine, Ontario Canada
				Rep Power: 18  | Quote:
 I paid $35 for the stock fd, better than the $80 rb wants. Do you machine the pump housing or the iron? I am thinking about doing this for the RE What are you using?
				__________________ 1986 GXL- Being built with a 13B RE... http://www.rotarycarclub.com/rotary_...ead.php?t=9602 1986 Base-RB Exhaust, HKS filter, Solid Aluminum motor mounts, S5 TII motor, ACT Clutch, HKS SSQV, Light Weight Flywheel, Haltech E6X, 720cc 2ndaries, Koni Yellows, Tein Springs Koyo Rad, 250 WHP 230 FTLBS Stock turbo, and stock IC at 10psi. RIP!! The daily bitch- 1995.5 Toyota Tacoma- Trueflow airfilter, and Bilstein HD shocks. 2009 Toyota Corolla "S" TRD Filter... 40MPG | |
|  05-09-2012, 12:25 PM | #7 | |
				Rep Power: 16  |
			Forgive my ignorance but what benefit does this provide? Quote:
 I guess I'm not up to speed on my oil system modifications... | |
|  05-09-2012, 05:47 PM | #8 | |
				Rep Power: 10  |
			Sounds right for retail   And more base pressure, and you don't have to pull your pan off to adjust it Quote:
 RX7 specialties Reduced the chance of a future failure, doesn't allow oil to bypass
|  05-09-2012, 05:47 PM | #9 |
				Rep Power: 10  |
			Where ya been Kevin?  Still not done w/that RE yet?  Damn man
|  05-09-2012, 07:06 PM | #10 | ||||||
				Rep Power: 0  | Quote:
 a warp seal might kill whatever you said as well, Mazda choose to heat treated their Apex tips for a reason. Quote:
 again, each to their own. there are people who use it and they're ok with it. so can't really say who is right/wrong, just a preference. I run Ceramics in mine. choose because it's easy on housing, and they last almost forever. sure they're harder and if they break, 99% will kill everything, but I am willing to take that risk. Quote:
|  05-09-2012, 07:13 PM | #11 |
				Rep Power: 0  |
			same idea as the front pulley bolt plug, there is a chance that it will fail, when it does, it always get stuck either open or closed position.  either one is bad for you. mind u they are loctite from factory, so if u wanna remove it and install a plug, u might want to hit that spot with a propane torch for 30 seconds first, then unscrew it fast. |
|  05-09-2012, 09:01 PM | #12 | ||
|  05-09-2012, 09:05 PM | #13 |
				Rep Power: 18  |
			Oh been busy making a baby, little girl 7 weeks old today, should have the engine built in July, should be able to start break in sometime around October.
|  05-10-2012, 08:43 AM | #14 | |||
				Rep Power: 10  |
			No.  I wasn't.  That's what those seals are designed for.  Any other seal I'm confident would've broken.  Leaving me with an 800 mile tow home, and a worthess set of rotors and housings.  I run those seals for a erason Quote:
 Wow... congrats man.
|  05-10-2012, 10:56 AM | #15 | |
