#1 | |
IT'S ALIVE!
Forgive my ignorance but what benefit does this provide?
I guess I'm not up to speed on my oil system modifications... |
#2 | |
Rep Power: 10 ![]() |
Sounds right for retail
![]() And more base pressure, and you don't have to pull your pan off to adjust it Quote:
RX7 specialties Reduced the chance of a future failure, doesn't allow oil to bypass
same idea as the front pulley bolt plug, there is a chance that it will fail, when it does, it always get stuck either open or closed position.
either one is bad for you. mind u they are loctite from factory, so if u wanna remove it and install a plug, u might want to hit that spot with a propane torch for 30 seconds first, then unscrew it fast. |
#4 | |
IT'S ALIVE!
I have radioactive semen
no. not bad. personally, i don't see a point to putting an engine together with the stock ball and spring. just don't go ape-shit with the jet size.
