			 Rotating Assembly
				Rep Power: 18 ![]()  |
				Boost falling off
			Relevant mods
			90 S5 Vert.With the EVC off, we were seeing a max of about 4.5psi so I'm assuming the wastegate spring is about 4.5pounds. We set the EVC to 50% and we were expecting about 7psi max (4.5 + (50% * 4.5)) but it went to ten; which was fine. As you can see in the Zeitronix chart, boost is maxing out at ~10psi at 4700RPM and drops off gently from there. ![]() We are using Aaron Cake's rule of thumb AFR tuning targets 0-4 PSI: 12-12.5but obviously the 1000cc secondaries still need to be pulled back some. IIRC we are pulling them back about 3% above 4500RPM. Is the fact that we're getting too rich after 4500RPM what's causing the boost to fall off or is the wastegate spring at fault? Thanks, appreciate any guidance yall have.
	![]() ![]() 90 S5 Vert. JDM Tii with BNR Stage1 turbo. Pineapple Racing street port. Bonez cat-forward. Corksport cat-back with Vibrant UltraQuiet resonator. RTek 2 wZeitronix w/b. HKS EBC. Vis CF Tii hood. 3000GT wing. Ground Control coilover kit with KYB AGX shocks. Red and Black leather RX8 seats. Corksport Odura lip & bumper caps, OEM Tii skirts  |
				Rep Power: 10 ![]()  |
			Aaron Cakes "rule of thumb" AFR's are stupidly rich.  I wouldn't follow anything of what he says.
			More important, what are your timing numbers like? The boost will fall off in the higher revs... this is just fact.
	-The Angry Stig- DGRR 2009, 2011, 2012 & 2013 - Best FC DEALS GAP!! WOOHOOOO!!!!! 2015 Audi S4 - Samantha - Zero Brap S4 2004 RX8 - Jocelyn - 196rwhp, 19mpg fuel to noise converter 2000 Jeep Cherokee Sport - Wifey mobile - Now with 2.5" OME lift and 30" BFG AT KO's! So it begins 1998 Jeep Cherokee - 5 spd, 4" lift, 33" BFG's - Rotary Tow Vehicle 1988 'Vert - In progress 1988 FC Coupe - Gretchen -The attention whore BEAST! I'm a sick individual, what's wrong with you? I'm pure Evil I'm still insane, in the best possible way. I think Brian's idea of romance is using lube. Your rage caused the meteor strike in Russia. The Antichrist would be proud of his minion. You win with your thread. Most everything It's a truck with a steel gate on the back. Just a statement of fact Motec M820, AIM dash, ported 13B-RE Cosmo, 6-spd trans, 4.3 Torsen, custom twin wg fully divided mani, Custom 4" split into 2x 3" exhaust, Custom HMIC, Custom custom custom custom I like to welder stuff.... No Bolt-ons allowed. Dyno'ed @ Speed1 Tuned by me - 405rwhp on WG.... WM50 cuming soon. -Angry Motherf*cker Mode ENGAGED-  |
				Rep Power: 19 ![]()  |
			1) Get an EGT gauge
	2) Learn how to tune with EGT 3) You're running too rich - too much fuel suppresses boost 4) Stop listening to Cake's bullshit -Ted  |
		#4 | |||
			 Half bubble off plumb
				Rep Power: 16 ![]()  |
 QFT!!!! ![]() So instead of tunging using target AFR's you are sugguesting using EGT's...? I thought (assumed) it was more accurate and "safer" to tune via AFR's not EGTs input from both You Ted and Bryan would be great, as I am trying to increase my knowledge to when I decide to start trying to tune.. J
 "The most respected cars in history are the ones which stick to their guns, do things differently and make no apologies for it." 360 gamertag: Tichlis Last edited by Prodigy; 02-27-2012 at 03:50 AM. Reason: decided to not troll  |
		#5 | ||
 ![]() EGT's will help you dial in the timing. For the people that have been doing it a long time, they can get damn close to target AFR's with EGT's
			 Rotating Assembly
			Wow!  That's a lot of vitriol thrown Aaron's way.
			I should have explained our goals and constraints. The car is my 21 year old's DD and all it needs to do is provide him fun, entertaining transportation until he graduates college. If it blows up and burns to the ground the second he receives his diploma then it has served its purpose. It will never be raced but we don't want it so neutered as to simulate a soulless but infinitely reliable Corolla. Since we rebuilt the PoS Tii we got from TigerJapanese 3 years ago the car has run nicely at stock boost with an SAFC to fatten up the top end of the range. Then in Oct'10 the turbo died and I had BNR rebuild it and had him do a Stage1 since it was just a bit more money. Then in July'11 the SAFC died so I got the RTek 2 upgrade (from a 1.8) installed as it was cheaper than buying another SAFC and had more tuning headroom. Over the winter I took the HKS EVC out of my 17 year olds MR2turbo and just ran it off the Tial's 12# spring since he doesnt need any more than that much boost. I believe that the FC's boost solenoid was lame because we were only seeing about 4.5 lbs of boost and when the ignition was on that solenoid would often buzz. So we put the HKS in the FC a couple of weeks ago and just this weekend turned it on and did a little street tuning; starting fat and leaning it slowly. So we are not looking to tune it within an inch of its life, not looking to drag race it, not looking to spend any money, not looking to search for a pro tuner who knows rotaries and is willing to touch an RTek. Just want to find a reasonably reliable, reasonably fuel efficient, reasonably performant DIY street tune that will get him to and from school and will pass TX emissions and inspections. Given that the stock turbo is frequently taken to 12psi I figured we'd set Mode A to 10PSI for daily driving and Mode B to 14psi as Brian@BNR said the Stage 1 was good to 1Bar. On the RTek we are using the default Fuel Correction Map configuration. I have neither the skill to mess with rotary ignition timing nor the interest in learning. It is hard enough to find rules of thumb like Aaron's AFR and I have never seen a HowTo for tuning a rotary with EGTs and timing. And unfortunately the price of being a little tiny bit wrong is a blown engine with destroyed rotor housings. So my take-aways from the replies are:
 Cool. We'll lean it out some more and see if that removes the 10psi ceiling. Thanks, Jim
			 The fan hit the shit!
			For a relativley stock turbo and motor, you can be in the mid to high 11's at 10psi, even 12 flat.
	There will always be some taper in boost with the stock turbo, it just can't hang in the upper rpms.  |
		   I run 11.7 @ 17psi... and @ 1br I'm running about 12 flat.  Then again... my ECU is a little more exact and responsive than an Rpuke.Cake really shouldn't be listened to when it comes to certain/most things alot of people with violently disagree with. Why some people have their rantings taken as gospel and looked at as rules of thumb is beyond me. Seriously though, is there anyway you can post up a timing map? I'm willing to bet there is a TON more power to be had out of your setup. The thing that alot of people don't realize is that you can be so far into the so-called "safe-zone" that it actually becomes dangerous and will pop your engine..... I refer you once again to 13B-RE Nova who had a thread in the single turbo section entitled.... why did my engine blow. Basically he was running low to 10flat AFR's @ 21psi and 6*'s of timing making a whopping, earth rotating 427rwhp on a GT42 or 45....... oh, and it was HBP'ed.... anyone care to take a guess why he popped his engine and why hc and bdc are totally and completely WRONG and stupid for suggesting that all he needed was colder plugs?
		#9 |
			^ most def, timing too retarded and afr's too rich can cause just a many probs as lean and way advance. def try to pull the leading and trailing maps off the rtek and post them up please!
		#10 |
			 Rotating Assembly
			We havent touched the timing maps at all.
			I've been using the Zeitronix for logging boost, TPS and AFR but I believe I can log the boost, RPM, and the timing via the RTek PocketLogger. Havent played with that at all. I'll try saving the configuration and see if the file is sync'd to the PC. That would have the stock timing maps in it. I know ARGHX tried getting the timing maps but it is tedious and so from what I can tell never happened. We'll give it a go later this week or this weekend.
		#11 | |
 WRT timing maps, the Rtek simply lets you directly overwrite whatever data is stored in the stock maps (in degrees). In other words, be very careful here because the consequences of a fat finger error can be severe, especially if you didn't keep track of the stock settings before making changes.  |
		#12 |
			 Rotating Assembly
			The kid returned from class so we went out and did a quick third gear pull.  It is currently 67 degrees and 60% humidity and we are at 600 feet elevation.
			The RTek log display program is not especially impressive so I took four screen shots at different points so you could see the numbers. The app ignores any attempt to change the color of timing series so I left them in separate bands. Probably makes it easier to see anyways. ![]() ![]() ![]() ![]() Again, these are all stock timing values. Thx
		#13 | |
			 Rotating Assembly
 Course hopefully that's before
		#14 |
			I hate to say it, but she really needs to be put on the dyno.  Those afrs are way to rich, and the timing seems to be a little weak.  Not to mention the split seems like it needs to be tightened way up too.  We generally run 10* split in boost, not 20, if im reading that right.
			If you're wanting to only mess with the fuel, set it for 12.5 @ 0 psi, 12 by say 7 psi, and nothing richer than 11.7
		#15 |
			 Rotating Assembly
			Yeah I read the thread on the single turbo forum you mentioned and I dont think they like you very much.
			![]() Both Brian Cain (BDC Motorsports) and Steve Kan are in DFW so if the kid wants to spend the $400 he's welcome to do the dyno thing! It's only a 3 hour drive and he can go to In-N-Out for lunch. Course he'd have to call and make sure they'd be willing to contaminate themselves by touching an RTek. We'll lean it out and see what happens. The preset is for 720/720 and we have 720/1000s and we added fuel across the map above 6psi just to be sure we weren't lean. We'll get the AFRs in line and then we'll come back and ask about timing.
