#1 | |
rotors excite me
Damn, you're sure I couldn't rough up the pit and put some liquid steel in there or something? When I got the housing there was black stuff built up in that pit so I cleaned it out. I'm not sure what the stuff was, but I certainly don't want my seal to bear the load of keeping that gap shut.
#2 | |
First, heat expansion... These epoxies do not expand and contract like the surrounding metal. Due to the heat cycling of the metal (i.e. aluminum), the epoxy will eventually work itself loose due to the heat cycling. Second, how does the epoxy react with the coolant? A lot of them do not like being immersed in chemicals. You need to confirm with the manufacturer that it is okay to be "submerged" with your coolant. Most epoxies do not like to be in contact with glycol based liquids and will eventually erode away. -Ted |
