Rep Power: 20 ![]() |
Yep, like a giant heat sink. It is hard to get it hot enough. Yeah I would just use or borrow an impact.
1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4 |
Waffles - hmmm good
I had one engine that was really stubborn and already out on the floor. I took
some 2" x 2" angle iron and drilled holes and mounted it to the mounting bolts on the front housing (12A) and then slipped a 6' iron pipe over my 25" breaker bar. Before that I heated it up real good with a torch. Even then I had to bounce on it hard a couple of times before it broke loose. That bolt seems to gall together with the pulley mount hub and the shaft until they are one! I've had more issues with those than any flywheel nut ever.
Clean S4 Nutswinger
Finally got it. We used a longer pipe and I stood on the engine stand while my dad leaned on the pipe.
I pulled the front cover, breathed a sigh of relief when I confirmed I ordered the right gasket/o-ring combo, then promptly sliced my thumb open on the CAS drive gear .
