#1 | |
You are making me rethink this motor rebuild and going to a newer one instead. |
The oil injection has been removed on that engine. Its common practice, especially in custom applications and when modifying/ changing carbs, etc. An arguably standard amount is 1 oz. per gallon of 2-stroke Tc-w3 added to the fuel. Your internal metal seals (apex, side, and corner seals) were not being lubricated (comparable to piston rings). Yo uprobably have quite a bit of internal wear and may be better off getting an entirely new motor. For simplicity sake I'd recommend staying with a GSL-SE block so you won't have any fitment issues.
'15 Juke Nismo '06 MX-5 GT SOLD '04 S Silver RX-8 GT Track Day Use SOLD '90 Black TII vert w/ Sprint RE stock port/turbo DD dyno (242.6whp@5500rpm @12psi 8psi@redline) and (250ftlbtq@4800rpm @13psi) SOLD '89 GTUs 6p TII SOLD, '87 sport SOLD, '79 SA stock SOLD '91 B2600i 4x4 w/ Rx-8 LSD SOLD Last edited by FerociousP; 09-12-2011 at 11:02 AM. |
OK, so now after reading that I guess I am looking for a GSL-SE block if anyone knows where to go to get one.
Please let me know and this time I will make sure to add oil to the fuel. ![]() I am looking in my area on Craiglist but found nothing so far. I really want to thank you for all your help.
I have another question.
Is this rotary a 6 port or a 4 port
its a 6 port, and those are really good motors.
![]() ![]() ![]() rotaryshack.com |
