Originally Posted by infernosg
Starting pulling the engine apart and found some more interesting things. Notice all the oil buildup. I think there was something seriously wrong with the front rotor/housing/iron - this thing is nasty.
That looks about normal for a long life engine. Maybe you should clean it more often
Here's a picture of the auxilliary port sleeve for the front rotor (far upper right port in the previous picture). Again, note the oil buildup.
Yes. That however, is not normal. My thought would be that the oil from the broken feed line has weeped into the gasket and soaked through that and has been deposited over time into the back wall portion of the sleeve. Something to consider is that the same debris that caused that build up also probably went into your combustion chamber.
Now here's the rear sleeve. Notice how this one is basically spotless but there may be a reason for that. When I tried to turn the actuators the drive the sleeves I could not get the rear to move AT ALL. It doesn't seem like it has moved in a while.
That is an easy fix. Mine did the same thing until I broke it loose. Use some penetrating oil (pb blaster and the like) on the internal chamber (you'll need to spray it into the hole) and on the shaft, let it soak in over night. Then chuck the actuator in a vice or secure it to a wood block and push the shaft to break any of the other debris. Flush with more penetrating oil. Once cleaned lobe some lithium grease onto the shaft and work it into the chamber via the shaft (don't try shoving it into the hole). That should free the actuators right up.
