Show your rotary car build up. Show off your Rotary Car build! |
Don Mega
After consulting with BDC and HC my theory is as follows
![]() After consulting with myself my theory is as follows....... Turbine expansion ratio is 1.55 on the new set up, it was 1.70 on the older set up thus 32% was "wasted" out the waste gate v's only 11% when running this turbo charger. The amount of heat held in by the smaller turbo is shown by the EGT and also the pressure (power level being equal) which I got as close as is possible in this test to demonstrate my point. Thus the EGT difference is down to the free flow nature of the turbine not retaining as much heat to make up for lower flow (energy balance to drive compressor is derived from heat, pressure, and flow rate) to keep the turbine spinning at the same rpm (to make the same power). The car is also quieter on full throttle/power v's the other set up, due to a majority of the gas needing to go through the turbine, nice side effect ![]() Yeah the air box and lots of stuff in the bay is SEX, I spent so much time making allot of it, its nice to sit back and just stare at it ![]()
Don Mega
More "box" for you
![]() ![]() It's a **** ![]()
www.riceracing.com.au Worlds best Apex Seals Coil on Plug Water Injection ECU Calibration Last edited by RICE RACING; 11-06-2010 at 06:44 AM. |
Bookmarks |
