Old 09-19-2010, 01:47 PM   #1
LunchboxCritter
Simply Rotarded
LunchboxCritter's Avatar
LunchboxCritter is on a distinguished road
Have you checked your fuel pump wiring?
You can check your compression with a standard compression tester. Here is an example, you can search youtube for other examples.
http://www.youtube.com/watch?v=DMflTrwgKss
LunchboxCritter
- 91 NA to J-Spec TII
- 88 FC Vert
- 04 Rx8
Disclaimer: I am not a mechanic, and I did not sleep at a Holiday Inn.
DO NOT TRY THIS AT HOME!!!
LunchboxCritter is offline   Reply With Quote
Old 09-19-2010, 07:17 PM   #2
atsronnyats
atsronnyats is on a distinguished road
there you go lunchbox....got the stethoscope out no sounds up front when inspecting the fuel pump in back again nothing....so yes a fuel issue definatly changed the filter anyway...
it got dark on me didnt have time to get the multimeter out will break it out tomorrow
btw it did the same thing...cranked right up but died out because it wasnt warm due to bad idle....it did this two more times before it ran and just died out and yeah the final time as if it abruptly lost fuel, trying to start from this point yielded the same results as before
the car was low on oil theres no fail safe is there cutting out out power to the pump?
atsronnyats is offline   Reply With Quote
Old 09-20-2010, 10:25 AM   #3
LunchboxCritter
Simply Rotarded
I do not believe that there is a fail-safe based on the oil level.
The pick up screen in the tank could be getting clogged up, so you might check that while you're checking the internal wiring to the pump.
I would recommend running new wires to your fuel pump, and definately make sure that you have a good ground for your fuel pump. There are some pretty good write-ups about how to do it; however, I'm fairly sure it's pretty straight forward as you're just replacing old wire with new, and securing a better ground.
LunchboxCritter
- 88 FC Vert
- 04 Rx8
Old 09-20-2010, 10:47 AM   #4
atsronnyats
Good stuff man this stuff is old as I am any way will check the stickies and go from there....
Old 09-20-2010, 01:47 PM   #5
My5ABaby
My5ABaby's Avatar
The only "fail safe" it has is that the idiot cluster will light up for low oil and the buzzer will go off. The same buzzer for redline/low coolant.
i dunno what checking the compression would help honestly only because it "works" fine but has a mysterious hot start issue...definately something i would think to check....and honestly something ive never checked on a rotary...will check fsm
A car with low compression will still "work" very well, it just won't pull as hard, but you'd probably never notice that. Low compression really begins to cause issues with things like hot start and idle.
Community Service Manual
RotorWiki
Old 09-20-2010, 05:35 PM   #6
atsronnyats
[comments removed]
Old 09-20-2010, 05:41 PM   #7
atsronnyats
1. all good to know. will check into i have a friend in mind with tool
2. still have the rewire (fuel Pump) to do im reading up on the for NA. also decided to change the fuel hoses/clamps didnt like the condition
Old 09-21-2010, 01:05 AM   #8
atsronnyats
so if my attachments work you will see from the fsm what im talking about....remember NA
1. on position no voltage at pump wiring harness (R0-3)...in yellow
note: i know two top supply voltage--- bottom two fuel level sensor
2. From FSM section 4A-74 **NA** when checking voltage at fuel pump relay...
a. ON position checked out
b. ig sw Starting no voltage from Fc which is "fuel pump switch"
c. failed to check (no time) with measuring plate open
until this point i was going to as you know rewire the fuel pump i have the materials and im in a holding pattern suggestions guys based on 1-2 info above
