				Rep Power: 0 ![]()  |
				stranded again what gives? ideas
			took the na s4 fc vert out last night for late night drivethru withdrawal, so as per usual i turn the car off to talk to the clown while waiting 4-5 mins i try to crank back up.....miss it (i have to wait for stater to stop) then try again once engine is once again turning over she decides thats all she will do. i cant remember exactly (rough night towed the fc home) but i do think there was a intermitent start there for a couple seconds not sure this is the point where i tried to restart. so yeah im pushing the 7 thru the drive thru get my drink and by a simple math error im only charged for what my girl ordered lol that did help at the time. got the (Free) food and attempt to push start it. it does start but has no ablity to accelerate i e no throttle responce at all. a dies and soon as the rpms die with it. i thinking flooded? i always think that lmao. so i pull the plugs they are dry of oil gas nada... with so black discoloration no ash or carbon deposits but black ya know. i went thru the rigoris deflood procedure with no luck it just turns over. so im thinking i wasnt getting fuel.
	OK here is the kicker after driving the minivan to work i get home and for shitz and giggles decide to try and start it. she offers no problems at all , first attempt fires right up to the 3k warmup.... i cant fix when i do have a problem only trouble is there is a problem? the 7 is messing with me ideas neone btw i am a noob to this forum, came from rx7club recently ATL based  |
		#2 | |
				Rep Power: 21 ![]()  |
			that's a lot going on in one post.
			RIght away sounds like a hotstart issue and severe flooding... 1. What's the mileage on the car? How old are your fuel injectors? Have they ever been replaced? 2. When was the last tune up (i.e. plugs, wires, make sure the TPS is set right and no flatspots, timing is dead on)? 3. the way you described the car dying when you give it throttle input makes me think you may have some sort of vacuum leak...have you checked for vaccum leaks? I recommend you videotape the next time this happens so we can see it...your posting style is difficult to read.
				Rep Power: 19 ![]()  |
			Fuel filter?
	-Ted  |
			1.yea all have been changed as of late in miles... as for miles 110k on the car
	2. i have replaced all vacuum hoses 3. reconditioned the injectors not long ago (2 & 3 done at same same time) 4. i do have replacement wires and plugs ready to go havent changed bc dont think its neccesary but i am asking yes 5. i guess i could replace the fuel filter i work at advance auto parts will pick one up today 6. changed the fuel pump the first time i had problem like 2k miles ago 7. i had extra coils changed them under the belief it was a spark issue  |
			i just got this car back from when it stranded me in florida luckily at my parents house.
	the same moved the car to load my stuff up switched car off. then no restart and failed attempts to push start parked it had it "fixed" got it back a couple weeks ago since then a idle has never been established... got it to where i can drive it... stopped with the ac running does present a problem also cold starts car will stall -if any of that information helps  |
			I had pretty much the same problem.  would start cold and drive fine but seemed very sluggish till I shut it off.  changed all the things mentioned above and nothing helped.  I had the compression checked and found out I had low compression in both rotors.  The only difference I guess is I was able to pop start mine(i dont know if this matters).  From what Im reading you arent able to do this?  I may be way off but have the compression checked
			i dunno what checking the compression would help honestly only because it "works" fine but has a mysterious hot start issue...definately something i would think to check....and honestly something ive never checked on a rotary...will check fsm
			i love the fact the fsm always uses special Mazda specialty tools i give my left nut for i.e. the compression tester as seen in the fsm anyway its mentions checking all THREE combustion chambers(gotta love it)NOTE: should read 85psi or  588kPa consistantly @250 rpm and list a variance ceiling (limit) of 21psi or 147kPa although it does vary with rpm it mentions has a cool XY chart
	just a fsm rant thought id mention it still wish i had the tool lol  |
		#9 |
			 Simply Rotarded
				Rep Power: 17 ![]()  |
			Have you checked your fuel pump wiring?
			You can check your compression with a standard compression tester. Here is an example, you can search youtube for other examples. http://www.youtube.com/watch?v=DMflTrwgKss
			LunchboxCritter - 91 NA to J-Spec TII - 88 FC Vert - 04 Rx8 Disclaimer: I am not a mechanic, and I did not sleep at a Holiday Inn. DO NOT TRY THIS AT HOME!!! Last edited by LunchboxCritter; 09-19-2010 at 01:51 PM.  |
		#10 |
			there you go lunchbox....got the stethoscope out no sounds up front when inspecting the fuel pump in back again nothing....so yes a fuel issue definatly changed the filter anyway...
	it got dark on me didnt have time to get the multimeter out will break it out tomorrow btw it did the same thing...cranked right up but died out because it wasnt warm due to bad idle....it did this two more times before it ran and just died out and yeah the final time as if it abruptly lost fuel, trying to start from this point yielded the same results as before the car was low on oil theres no fail safe is there cutting out out power to the pump?  |
		#11 | |
			 Simply Rotarded
 The pick up screen in the tank could be getting clogged up, so you might check that while you're checking the internal wiring to the pump. I would recommend running new wires to your fuel pump, and definately make sure that you have a good ground for your fuel pump. There are some pretty good write-ups about how to do it; however, I'm fairly sure it's pretty straight forward as you're just replacing old wire with new, and securing a better ground.
	LunchboxCritter - 91 NA to J-Spec TII - 88 FC Vert - 04 Rx8 Disclaimer: I am not a mechanic, and I did not sleep at a Holiday Inn. DO NOT TRY THIS AT HOME!!!  |
		#12 |
			Good stuff man this stuff is old as I am any way will check the stickies and go from there....
		#13 | |
				Rep Power: 20 ![]()  |
 A car with low compression will still "work" very well, it just won't pull as hard, but you'd probably never notice that. Low compression really begins to cause issues with things like hot start and idle.
	1986 Sport: 132k miles, 5A (Sapphire Blue Metallic), Tokico Blues, Racing Beat Springs, Custom LED tailights (only S4 LED tails in the world), SSR Mark II, Racing Beat exhaust, S5 black interior, Rotary Resurrection rebuild at 120k miles Community Service Manual RotorWiki "Imagination costs nothing; we could build square locomotives or fly to Mars" - Felix Wankel Yesterday is history, tomorrow is a mystery, but today is a gift. That is why it is called the "present."  |
		#14 |
			[comments removed]
			Last edited by atsronnyats; 09-20-2010 at 05:43 PM. Reason: fixed...see next post  |
		#15 | |
 2. still have the rewire (fuel Pump) to do im reading up on the for NA. also decided to change the fuel hoses/clamps didnt like the condition  |
