Old 07-15-2010, 09:01 PM   #1
I've had good success opening the exhaust a little sooner. I generally don't touch the exhaust closing or intake opening on turbo engines. Has worked well for me in the past.
Are you going to portmatch all the main's/block Kevin?
Looks good so far...... from what I can see anyway...... do you own a camera
Old 07-15-2010, 09:38 PM   #2
Nismo
400WHP or bust
Nismo's Avatar
I I just ported to the bottom of the stock chamfer, and added a new one! I guess I could post better pics, but that requires work, I'll get some later if you are good I'm no porting god, and I never will be.
I have port matched all the manifold yes.
Old 07-16-2010, 07:27 AM   #3
classicauto
crash auto?fix auto
classicauto's Avatar
neither was dave gibson, and yours look much better
I like the stock overlap port job. Someone else in ontario decdied to do that with a single turbo'd rhotormhotor......
So can we drink beer and point at your engine pieces at BCM or what??
Old 07-16-2010, 01:02 PM   #4
Nismo
400WHP or bust
Nismo's Avatar
Yeah well Dave was a weeeeeeee bit slow...
Sure yes... Stock overlap? I guess you are the other one? I like just porting the exhaust because I want this thing to last a bit, and it should have Stock port FD drivability, and Single turbo reliability! The exhaust port should spool the hell out of the TO4E
Lol, I won't be bringing them along, I just painted them, and I want to keep them clean, and chip free, they are covered in fluid film right now, it makes things a real mess in a hurry!
