| Interior, Stereo, Body kits, etc... Place where you could talk about car care, body kits, painting your car, Carbon Fiber, Thumping Stereo, etc.. |
Advice on bodywork for an FC?
Hey guys, as some of you might know, I'm in the process of repainting my FC turbo.... Problem is, There's still a lot of work to be done, and I only got 3 more classes scheduled.
I have a daily, so the FC could be finished during the fall autobody class, but I dont want to wait till winter for it to get done, ya know? Do you think that using a paint booth to paint your car is absolutely necessary? And, how about baking the car in the paint booth? Right now, it looks like if I want to get this thing even close to done by the end of the summer, I will need to paint it myself, most likely in my garage. I already bought the paint and a bunch of supplies too. So, I guess the question is... should I wait? I looked into what I need: $150 compressor (big enough for a paint gun and an ok D/A sander) $100 paint gun starter kit: comes with 2 guns and everything I need. $40 el cheapo D/A sander. Now, that's quite an investment, but I would be able to paint other cars, and finally have an air compressor to work with. Or, I could wait, and just get it done when classes resume in late august... I dunno, but part of me is telling me: screw it, buy the shit and do it now!
Rotorhead
Do you know all the steps involved in painting a car? I do know right off the bat its alot of work? Do you have any previous expericence paint cars? Do you drive your car during the winter time? How clean is your garage ? How clean is the paint booth at school? Baking the paint after its been settled is a good way to speed up the process of drying. Try to weigh out the pros and cons of painting at home in the garage and in the shop at school. I've been waiting almost a year to paint my car too. I have most of the scruffing supplies and base paint. But still needs more money.
The actual paint and clearcoat at whats going to hurt the most money wise.
Currently running: 90 GTUs converted to S5 TurboII. Track car. 90 N/A GTUs.. Running project car 89 N/A GTUs in Black #2 10/6/18 Blown coolant seal undergoing rebuild and restomod. |
Can't.Make.Up.My.Mind.
Painting In Your garage would be fine. Just know that it's probably going to be a dirty paint job compared to If you use the paint booth at your school. Which will probably result in quite a bit of wet sanding. I have a degree in collision repair and refinishing. My advice is ti use the booth if you can, you will be glad you did
.Also....I doubt you're gonna get a compressor for 150 that will sufficiently power a DA and a gun. I just bought a portable 33gal compressor for my DA and gun. It was $350. DAs use ALOT of air. My compressor barely cuts it and all I'm doing right now is putting some flares on my friends FC. I would hate to do a whole car with the compressor I have. Sanding wise i mean. It should power then gun just fine. I would say get a 60 gal. That should work just fine. Also about the baking. You only need to bake clearcoat. Base dries quite fast. I learned with BASF Products (Limco,RM,Glasurit). Flash time between coAts with these paints is about 5 to 10 min. Baking the clearcoat is a great way to help it dry. But it's not always necessary. Keep us updated
'90 GTUs Stay up to date with my photography '06 Toyota Highlander Hybrid '10 Toyota Prius "Initial Success or Total Failure" Last edited by project86; 07-13-2010 at 11:22 AM. |
I have a 60 gallon compressor that flows around 10 SCFM @ 90 psi. Before you buy tools or as you buy them, look to see what air delivery they need to keep running effieciently. I don't have a DA sander, but I do have a grinder that my compressor can keep up with no problem. It should definitely be good for a paint gun no problem, as the gun I will be using requires around 13 SCFM @ 30 psi. Compressors that flow that kind of air are often 240V, so be prepared for that too.
This was also a $400 compressor and was the scariest thing I've done in awhile unloading it off of the Home Depot rental truck. I'm attempting to do all the body work and painting in my garage. It requires a lot of research before you decide to go ahead with it. Just outfitting the garage to this point cost a lot of money - to the tune of nearly $1000 for an air compressor, a 240V outlet, good sanding blocks, paint guns, grinder, respirators, body filler, etc. I haven't even purchased the main ingredient yet - paint, which I priced out at $500 on the extreme low end.
Jerry 1991 Mazda RX-7 Turbo - the current project/money pit |
^^ Jerry is right. Those are all good things to consider.
'90 GTUs Stay up to date with my photography '06 Toyota Highlander Hybrid '10 Toyota Prius "Initial Success or Total Failure" |
crash auto?fix auto
Keep in mind - painting in your garage doesn't mean you're painting in your garage.
It means you' be painting the garage ![]() If its not properly sealed up. Not to mention, in order to keep dust down you'll want the door down. In which case by half way down one side you will no longer be able to see the car. Unlles you have adequate ventilation. You might get away with it on a full HVLP setup, but again I doubt you have a real HVLP gun, or a 13+CFM compressor to power it. A booth is a tool, an extremely necessary one. There's alot to a paint job. Wait that's not right at all..........there's alot to a properly done paint job - so don't rush it unless you don't mind if it shows. |
#7 | |
Thanks.
i have noticed a difference in gun quality. I used a SATAjet 3000 for 2 years and then at my old job they only had shit for guns and its different.
#9 | |
crash auto?fix auto
There's HVLP, compliant, and non-hvlp(old tech). The point of it is higher transfer effciency, (ie. less overspray!) finer atomization......but they consume alot of air. They work excellent, although honestly if you've not sprayed with each type you wouldn't know the difference you'd just think thats how it is. But a compliant (decent transfer effciency) or old style gun (shitty transfer effciency), although it will consume less air, will be spraying at a higher pressure and blasting tonnes of paint into the air - and also getting some on the panel ![]() Full HVLP setup meaning you don't simply buy an HVLP gun and go nuts. You need larger diameter lines and fittings to feed the higher volume into the gun. Also, your compressor *ideally* should be over 20CFM on an HVLP setup. Brands....meh not so much. They all spray a little different I find its better to fit the gun to your style then the other way around. I've been a devilbiss fan for a while. The anesta Iwata gun's i've been using lately are nice....I do like SATA alot, but hate having to get parts for them, and my style doesn't fit they're pattern as you generally have to be much closer to the panel then I'm comfortable with to get proper transfer. Going with a non china gun - you go with what fits your style. Going with a cheap thing, well who knows. Chances are two of the same cheapies would spray differently then each other.
#10 | |||
Rep Power: 10 ![]() |
Just noticing things here. Quote:
#11 | |
#12 | |||
NO shit right? I my Snap-On DA was around $250 if i remember correctly with my SEP discount with Snap-On. Im was and am still going to buy a SATAjet basecoat gun (1,4 tip) thats $700 just for one gun! Plus prep is one of the most expensive parts of the paint job and the most important part to the final outcome. Quote:
![]() Quote:
( or have you ) id say youre doing just fine.ClassicAuto: Do you paint professionally or is it just a hobby for you as well? You really seem to have a firm grasp on all this (not to sound like im like a paint god or anything). Its just nice to see someone else (Brian included) that really knows something about it and can help explain to people who dont know.
#13 |
Yowsers! I'd certainly like to spend that much, but just can't. One thing the paint supply place I talked to recommended was to maybe go with a slightly cheaper paint and a better clear.
#14 |
That can work. What brand are you using for paint? Ive used Limco basecoat and covered it with RM clearcoat and im getting ready to do it again because it worked so well. I would say check with the paint rep to make sure that they will work alright together and not cause you any problems down the road. Just because both products are made by the same parent company (Limco/RM/Glasurit in my case all owned by BASF) doesnt mean that you can mix the 3 brands and have a long lasting paint job. Id say just make sure you really do the research on it. You would hate to have a bad solvent pop issue or fisheyes or bad adhering because of something like that.
#15 | |
crash auto?fix auto
Project86 - yes I do this professionally ![]() As for spraying over cheap base coat with good clear - it can be done. Generally speaking, something like limco base (limco 4?) is *decent* product, but what makes a top end product isn't always just about material "quality". Limco paint line has alot of matches for factory colours, but they won't be as accurate as RM, Onyx or glasurit, they won't dry as fast, they may not cover as well etc etc etc. There's far more to a premium paint then simply durability - although durability is part of it. But in the case of a single paint job, often the cost savings can be worth it for a one timer or hobbyist. In a production shop setting you have to look at price vs. true cost so thats where premium lines really win out. Make sure to verify via a tech line what products are recommend to top coat whatever you're spraying for colour. Alot of the time, most anything will do. But in some cases specialty clears may not be recommended over low end base, so be certain whatever you're combining *will* work.....according to the paint manufacturer. |
