| Interior, Stereo, Body kits, etc... Place where you could talk about car care, body kits, painting your car, Carbon Fiber, Thumping Stereo, etc.. |
crash auto?fix auto
Keep in mind - painting in your garage doesn't mean you're painting in your garage.
It means you' be painting the garage ![]() If its not properly sealed up. Not to mention, in order to keep dust down you'll want the door down. In which case by half way down one side you will no longer be able to see the car. Unlles you have adequate ventilation. You might get away with it on a full HVLP setup, but again I doubt you have a real HVLP gun, or a 13+CFM compressor to power it. A booth is a tool, an extremely necessary one. There's alot to a paint job. Wait that's not right at all..........there's alot to a properly done paint job - so don't rush it unless you don't mind if it shows. |
#2 | |
Thanks.
Jerry 1991 Mazda RX-7 Turbo - the current project/money pit |
#3 | |
crash auto?fix auto
There's HVLP, compliant, and non-hvlp(old tech). The point of it is higher transfer effciency, (ie. less overspray!) finer atomization......but they consume alot of air. They work excellent, although honestly if you've not sprayed with each type you wouldn't know the difference you'd just think thats how it is. But a compliant (decent transfer effciency) or old style gun (shitty transfer effciency), although it will consume less air, will be spraying at a higher pressure and blasting tonnes of paint into the air - and also getting some on the panel ![]() Full HVLP setup meaning you don't simply buy an HVLP gun and go nuts. You need larger diameter lines and fittings to feed the higher volume into the gun. Also, your compressor *ideally* should be over 20CFM on an HVLP setup. Brands....meh not so much. They all spray a little different I find its better to fit the gun to your style then the other way around. I've been a devilbiss fan for a while. The anesta Iwata gun's i've been using lately are nice....I do like SATA alot, but hate having to get parts for them, and my style doesn't fit they're pattern as you generally have to be much closer to the panel then I'm comfortable with to get proper transfer. Going with a non china gun - you go with what fits your style. Going with a cheap thing, well who knows. Chances are two of the same cheapies would spray differently then each other.
#4 | |||
Rep Power: 10 ![]() |
Just noticing things here. Quote:
#5 | |||
Can't.Make.Up.My.Mind.
NO shit right? I my Snap-On DA was around $250 if i remember correctly with my SEP discount with Snap-On. Im was and am still going to buy a SATAjet basecoat gun (1,4 tip) thats $700 just for one gun! Plus prep is one of the most expensive parts of the paint job and the most important part to the final outcome. Quote:
![]() Quote:
( or have you ) id say youre doing just fine.ClassicAuto: Do you paint professionally or is it just a hobby for you as well? You really seem to have a firm grasp on all this (not to sound like im like a paint god or anything). Its just nice to see someone else (Brian included) that really knows something about it and can help explain to people who dont know.
'90 GTUs Stay up to date with my photography '06 Toyota Highlander Hybrid '10 Toyota Prius "Initial Success or Total Failure" |
Yowsers! I'd certainly like to spend that much, but just can't. One thing the paint supply place I talked to recommended was to maybe go with a slightly cheaper paint and a better clear.
That can work. What brand are you using for paint? Ive used Limco basecoat and covered it with RM clearcoat and im getting ready to do it again because it worked so well. I would say check with the paint rep to make sure that they will work alright together and not cause you any problems down the road. Just because both products are made by the same parent company (Limco/RM/Glasurit in my case all owned by BASF) doesnt mean that you can mix the 3 brands and have a long lasting paint job. Id say just make sure you really do the research on it. You would hate to have a bad solvent pop issue or fisheyes or bad adhering because of something like that.
Probably PPG, but I've yet to settle on anything in the paint department. Heck, I'm still mulling over a color change.
#9 | |
crash auto?fix auto
Project86 - yes I do this professionally ![]() As for spraying over cheap base coat with good clear - it can be done. Generally speaking, something like limco base (limco 4?) is *decent* product, but what makes a top end product isn't always just about material "quality". Limco paint line has alot of matches for factory colours, but they won't be as accurate as RM, Onyx or glasurit, they won't dry as fast, they may not cover as well etc etc etc. There's far more to a premium paint then simply durability - although durability is part of it. But in the case of a single paint job, often the cost savings can be worth it for a one timer or hobbyist. In a production shop setting you have to look at price vs. true cost so thats where premium lines really win out. Make sure to verify via a tech line what products are recommend to top coat whatever you're spraying for colour. Alot of the time, most anything will do. But in some cases specialty clears may not be recommended over low end base, so be certain whatever you're combining *will* work.....according to the paint manufacturer. |
#10 | ||||||
![]() Quote:
![]() Quote:
#11 | |
