Old 11-30-2009, 11:52 PM   #10
jgrewe
jgrewe is on a distinguished road
There are enough maps out there on the forums that you can have your car drivable with a MS within an hour of initial startup. Help is the MS forum away for anything, Ihad an issue once that took as much time as it took to hit the refresh button for an answer. When I first built one about 4 years ago I think I read for a month before I was comfortable enough to do it. This was before you could buy everything from one place and you had to order stuff from 3 different places.
Aaron Cake's write up is probably the best I've seen for a car specific set up. The only difference I went with is the Zeal daughter card for the extra VR circuit instead of building a circuit in the proto area.
With the MS there are probably 9 ways to do anything. Once you get a hardware setup you like you can stick with it(until MS3 comes out and you want to do a new install...lol)
New rat from the sinking ship.
jgrewe is offline   Reply With Quote
