#46 | |
Rep Power: 20 ![]() |
#47 |
Rep Power: 21 ![]() |
alkaline is anything over 7 on the PH scale.
#48 |
if that's the case, wouldn't distilled water be beneficial in equalizing the chemical reaction potential of the coolant? Assuming Distilled water is close to 6.5 or at the most 6 on the pH scale, and adding coolant in a 50/50 mix will jump it up to 7.3-8pH wouldn't adding the additive only marginally increase the pH to something more alkiline?
This is rather interesting to me.
#49 |
I would have to agree that the affects of using that additive in conjuction with distilled water and an AL safe coolant will be marginal. If anything, it'll tip closer to the alkaline level of the pH scale which is ultimately better than being acidic.
You maybe better with using a 60/40 though - it'll balance better IMHO. 50/50 would be good when not using that additive. How many ounces is that bottle? I know the stock coolant system is a little over two gallons I believe, we can probably figure this out, lol... |
#50 |
the other thing is that "close" neutral and neutral are still pretty different as far as science is concerned. Also things dont have over night either. Unless you have a Ph of like 11 or 12. But say its 8 or 6. Well your going to find yourself chemically reacting til things settle out.
#51 | ||
#52 |
well that makes sense then if its about 8.3
#53 |
Agreed. You should take measurements initially and then each day for about a week after driving. I'd be curious to see what the rate of reaction is and what it finally settles out at w/ that additive.
Somebody should do a control experiement as well w/out the additive. I don't have an engine or I would take care of this, lol... |
#54 | |
I'm thinking something like this: http://www.lesliespool.com/browse/Ho...400020/I/82053
The Official FC Radiator Thread My Project Thread: Cerberus CCVT Virginia Rotary Group Last edited by vex; 09-11-2008 at 02:36 PM. |
#55 |
strip testing kits are pretty inexpensive.
#56 |
Tongue works too- if it's acidic, it's sour. If it's basic, it's bitter.
Oh wait, this stuff is poisonous right? Forgot...
#57 | |
I threw away the POS stock electric fan, and I wired in a relay through the existing circuit. I had my SPI water temp gauge monitoring everything. The warning light was looking for a specific resistance through the circuit, and the relay wasn't enough - it would light the warning light anytime the fan would trigger - was rather convenient at the time. Now I use a Spal PWM-FAN controller using the SPI water temp sensor. Side note on the whole corrosion thing... Distilled water is not as bad as RO water; I think the "leeching effects" are rather mild versus RO water. Oxidized aluminum makes a very effective barrier against corrosion - this is the whole idea behind aluminum anodizing. -Ted |
#58 |
Time for a resurrection
Ted, how did you fit the radiator in your 7? No matter how I cock it I can't seem to get it to lay correctly without having it stick out the bottom below the oil cooler, or interfere with the front sway bar. I'm honestly thinking about switching to a smaller height radiator to allow me to do a completely vertical mounting of the radiator.
#59 | ||||
Rep Power: 10 ![]() |
Never exceed 187*F 168-173* on the highway, will hit 180-185* after 4 hours of constant 4th gear dyno pulls Quote:
![]() It's a Griffen universal, singlepass, Ford/Chevy opposite side in/out which worked out better for my setup. Cost was about $180 IIRC. I've found that ducting is the key. Quote:
#60 | |
shookmotorsports.com
