Rep Power: 20 ![]() |
I think this is the fastest I've ever seen anything be developed LOL. Well done, well done.
![]() ![]() I'm eager for people to measure for the PS and AC, and I might see if my buddy can measure between the engine and pump on my car. Or I might just get one regardless, knowing I can easily resell it if it doesn't fit my setup lol.
#2 | |
Get off my lawn!!!
Rep Power: 15 ![]() |
'94 Touring - Cursed '96 NA Miata '14 Mazda3 Hatch '14 Aprilia RSV4 R |
Don Mega
From my memory they are the same dimension so yes, but will validate that this morning my time and post back.
#4 | |
Rep Power: 10 ![]() |
Just run the 7420's dude.... the reason I generally rec AGAINST colder plugs is because the ign system isn't up to snuff to properly fire the plugs. Change to colder shitty 6750 I think???? and need to "retune" the car because the AFR's are all over the place, then as you're pulling fuel out you see the EGT's go up... fuck that noise...... These coils I don't see as having a problem.
But I don't wanna! lol I had the mounting bracket welded to the frame with the bolts sticking out, and I don't want to move the pump again and just leave all that exposed. If I could remove the bracket and make it look good like the stock frame again, I'd seriously think about it.
Don Mega
OK!
I did a major redesign config, this is the best I can package it for OEM use. Tell me what you think? its under 14mm past the front edge of the rotor housing now! *New engine bracket mount *New coil spacer mounts *Re-Oriented COP adaptors ![]() ![]() ![]() ![]() ![]() ![]()
www.riceracing.com.au Worlds best Apex Seals Coil on Plug Water Injection ECU Calibration Last edited by RICE RACING; 01-06-2015 at 07:59 PM. |
Wow, I didn't think it was possible to get them any more compact lol. That's pretty awesome.
#8 | |
Don Mega
#9 |
LOL it sure is.
#10 |
I've said this about a million fucking times.... I REALLY hate making sparkplug wires.....
When can I order the COP adapters
#11 | |
Don Mega
![]() Just finishing off the design LOL (never ending story)!!!! last bit is O'ring sealing ..................... ![]()
#12 |
Don Mega
A cautionary note: DIY'ers
My system is precision, IE there is no real weight of the coil assembly on the spark plugs themselves, all of this load is taken by the engine mounting bracket and transferred through the coil mounts to the single fasteners for each module, the spark plug and coil end are 'rubber mounted' through the O-Rings. IF you are going to do your own mounts you will need to do it to precision to allow no loads on the plug ends. Just a note when I was talking to M&W today (who is kind enough to send me his latest CDI bespoke coil) and I will be designing a system around those for EXTREME Drag and other highest power use that mandates a CDI system.
#13 |
Don Mega
Here is a rough pictorial position relative to the front plate for those who like real pictures
![]() ![]() ![]() ![]() ![]() ![]() These pictures show the aspects of my design that make it so solid! The coils spacers are supported against a shoulder thus eliminating 'torque' related movement downwards upwards forces, and they both interlock against each other and butt up against the lower lug of the engine bracket. Its unfuckable and very very strong, despite its compact dimensions and small fasteners ![]() ![]()
www.riceracing.com.au Worlds best Apex Seals Coil on Plug Water Injection ECU Calibration Last edited by RICE RACING; 01-07-2015 at 01:49 AM. |
#14 |
Still Building my FD
Rep Power: 17 ![]() |
In for a set of the new compact design. I'll just make a bracket for my AC and alternator that clears the coils.
Uh.... hi. |
#15 | |
Don Mega
I could be wrong though, wont be the first time will explore the vertical mounting options.
