#31 | |
Don Mega
![]() and yes taxation is based on equivalence (to std common/majority 4 stroke reciprocating engines) and thus in 720deg the 13B does inhale (suck!) or partially displace 2616cc as shown............... but as we all know and can see it has NOT completed its full Wankel Cycle in that time, this only happens in 3 full revolutions of 1080deg.
#32 | |
OK, so my guess is that this is a 2499 magnum!
#33 |
Peter and Barry, I have too much respect for both of you to stand idly by while you dispute so vehemently.
It's Ok to disagree, but let's not turn this into an personal argument. This is a case where the only important factor is that we understand how the engine works. It is accurate to say that a rotary engine completes an intake, compression, power and exhaust stroke on each rotor during a single rotation of the engine. However it requires 3 revolutions of the engine for all faces of each rotor to see all four strokes. The difference between you is that Barry is looking at a single rotor housing as the displacement-providing chamber, while Peter is looking at the rotor as the displacement-providing chamber. Neither of you is right or wrong, it is a difference of perception. How each of us slices this up depends on personal preference and nothing more. There is no right answer here. I appreciate the information and clarification provided in this thread, but I don't want two knowledgeable and intelligent members of this community bogged down in this senseless argument. Let's leave it with the cycle explanation and keep this thread informative.
#34 |
Hey DOHC, who are you calling knowledgeable?
![]() Just one more thought to keep in mind. We have all driven different size engines with standard transmissions. When you let the clutch out on a rotary what size engine does it feel like? A- 3900cc engine. B- 2600cc engine C- 1300 cc engine |
#35 | |
Reasons why rotary engines feel soft, and they really are at low RPMs have roots in inherent engine configuration and its design flaws. Even Kenichi Yamamoto states exact reasons why is it so. Gas leakage through numerous gaps of gas sealing coupled with 1.5 times slower working cycle - losses losses losses
#36 |
Don Mega
Forums!
Difference between me and Barry is I am right he is WRONG! I get paid to teach people for a living! He comes to forums cause no one will pay him to teach people ![]() You can bury your head in the sand as much as you like, if you cant accept equivalence or know what an internal combustion cycle is or how all elements of an engine are accounted for then there is not much hope left for you to learn. It is not a hard concept, for some though I agree its a mountain v's for others a mole hill. Good luck to you, one day you will learn something, I suggest you go to school and spend less time on the internet.
#37 |
Don Mega
I'll leave you with one simple point to ponder!
Why when you do a compression test do you measure ALL THREE FACES over 1080 degree's? per rotor? Why is the engine classed as not healthy and due for rebuild if ANY ONE of these three faces per rotor is below another by any great margin? Why wont the engine function normally with only two apex seals per rotor if its only 1308cc for a 13B? Why Why Why Why Why?????? Cause Rice racing is RIGHT!@ You are WRONG! ![]() Have fun in your thread when you want to learn about engineering feel free to E-Mail me
#38 | |
Big Ugly
Rep Power: 17 ![]() |
I see nothing wrong with a healthy discussion & info provided with proof/facts, but I do agree with NoDOHC that insults do nothing for the topic.
Boosted Big Body On 335's PS3 ID: Rotordad 1986 Mazda RX7 GXL - Street ported 13BT, Haltech, 62mm, ect. 2006 MazdaSpeed 6 - Eagle, Wiseco, Cobb, ect. Last edited by RotorDad; 06-05-2011 at 06:50 PM. |
#39 | |
Still Building my FD
Wow.... you are so off base its amusing. ALL engines, 2 stroke, 4 stroke, rotary... are using only one rotation of the crank shaft to measure displacement. If you use your logic, then the 6.0 liter ls2 engine would really be a 3 liter 2 stroke engine if you built a custom head for it and ignited fuel every revolution? ... I am sorry, but you are wrong. The bore and stroke never changed therefore, your logic is home to a MAJOR fallacy. Wow.. you are arguing that somehow the method of measuring displacement has anything to do with which apex seals are required. To measure the displacement of a rotary engine, you would total the amount of volume displaced by one face of each rotor and add it up. Just like in a piston engine, you would take the displaced volume of EACH cylinder (notice how 4 stroke or 2 stroke doesn't matter) and add them together. Displacement calculation DOES NOT take into account how many revolutions it takes to actually fire each piston or rotor face. I have a lot of respect for you rice racing, but you are very far off base here. Displacement caluculations are simple: How much volume is displaced by the engine (regardless of type) in 1 rpm of the crankshaft/eshaft IS your displacement. Its fact, non-arguable. You can do displacement calculations without the heads on. it doesn't matter if it is 2 or 4 stroke. Hence why they do all 2 and 4 stroke piston engine calculations like so: stroke x bore x # of pistons = displacement. which would be the EXACT same as: displacement of each piston added together x 1 rpm. The 1 rpm factor must remain the same between all engines to have an effective and consistent method of calculating displacement.
Uh.... hi. Last edited by Monkman33; 06-05-2011 at 06:47 PM. |
#40 |
The key thing here is that people are arguing different things. "taxation displacement" has nothing to do with the actual definitive displacement of an engine. And determining displacement by the argument of "every rotor face/cylinder needs to fire" is faulty at best. For this to be even remotely true, then you would have to calculate 2 stroke and 4 stroke displacements differently. The fact of the matter is: This just doesn't happen. So these imaginary figures based on taxation methods or requiring every cylinder or rotor face to fire are just that. Imaginary figures that do not take into account he constant of 1rpm. Without this constant, there is no mathematical consistency, and then the game becomes fault riddled.
Displacement is universal to all engines as the displaced volume from 1 crankshaft/eshaft/centershaft revolution. 2 stroke or 4 stroke or rotary does not change this.
Uh.... hi. |
#41 |
Big Ugly
I remember reading this sometime ago & some of you may have read it also.
http://rotarygod.com/index.php?title=RE:_Displacement
Boosted Big Body On 335's PS3 ID: Rotordad 1986 Mazda RX7 GXL - Street ported 13BT, Haltech, 62mm, ect. 2006 MazdaSpeed 6 - Eagle, Wiseco, Cobb, ect. |
#42 | ||||
Rep Power: 20 ![]() |
Fuel to the fire:
#43 |
All of those support what I am saying, even though worded oddly in one of them.
The example from howstuffworks.com is assuming a 4 stroke engine. However, if you were to look at the same engine without ahead of valvetrain on it, it would displace the same total in one crankshaft revolution. Their example speaks of "ingesting" total displacement over 2 revolutions" which is true, because the term "ingesting" really has nothing to do with measuring the displacement, that has to do with engine type, 2 or 4 stroke). So, with the added support of your posts, I will stand even more firmly on the definition of displacement bing the total volume displaced through 1 revolution of the crankshaft/eshaft/centershaft regardless of engine type. The air that the valves allow to be ingested has nothing to do with the engine's actual displacement. That just determines th engine type.
Uh.... hi. |
#44 | |
I honestly don't know why "rotarygod" feels he has merit to claim anyone else is wrong. That's pretty much saying that the definition of displacement in relation to internal combustion engines is wrong. Its always been in direct relation to 1 revolution of the crank, regardless of stroke (2, 4 or '6') All these crazy arguments of multipliers are just relative arguments but are all lacking the fact that 2 and 4 stroke engines calculate displacement the exact same way. You don't need valves or a head to calculate displacement. just the bore are x the stroke x the number of pistons, which is going to net you exactly what I have been saying all along. 1 revolution worth of displacement. Starting position of the piston or rotor face DOESN'T matter as long as you go through EXACTLY one revolution of the crankshaft/eshaft. So here are the key notes that need to be seen here: Displacement is: -based on 1 revolution of the crankshaft/eshaft/centershaft -2/4/'6' stroke is irrelevant -physical volume displaced per revolution regardless of stroke style -multipliers are "rules or regulations" in place to even out the playing field due to the different power levels, and efficiencies of the different stroke types. (of course different methods of making power will yield different results) -Nothing mystical or hidden. I am not trying to make anyone look bad, only showing that this thread is turning into a magical goose chase of some mystical formula that must be used to calculate true rotary engine displacement.... The problem is, so many people are not willing to admit that the rotary CAN be rated in the exact same method as piston engines. And that is precisely what Mazda did.
Uh.... hi. |
#45 |
Peter, please don’t take this so personal.
We had a saying in industry that all of us should apply on the forums. And that is, ” It is OK to disagree. It is not OK to be disagreeable". We are sharing ideas to further the Rotary's development. You make your points well, especially the picture presentations. We need to just supply facts to support our point of view and then let it go. We just disagree on this point. Barry |
