|  06-02-2011, 09:36 AM | #16 | |
| Waffles - hmmm good Join Date: Aug 2008 Location: Huntersville, NC
				Rep Power: 0  | Quote:
 Rice, that was a great demonstration with the pics.
				__________________ 1980 GS stockport, Fat Nikki, RB Dual Facetfuel pumps, Holley regulator, RB Street port exhaust, 2GDFIS, MR2 MK I electric fans, 2G strut bar, relayed fans, lights and fuel pump, LEDs Project Fat Nikki Budget 12A rebuild Video setup < $30.00 | |
|  06-02-2011, 09:38 AM | #17 | |
| Sigh..... Join Date: Feb 2008 Location: Murfreesboro, TN
				Rep Power: 20  | Quote:
 I don't want to buy a 3.9L or 2.6L engine that makes 146hp. I want to buy a 1.3L engine that does.
				__________________ 1986 Sport: 132k miles, 5A (Sapphire Blue Metallic), Tokico Blues, Racing Beat Springs, Custom LED tailights (only S4 LED tails in the world), SSR Mark II, Racing Beat exhaust, S5 black interior, Rotary Resurrection rebuild at 120k miles Community Service Manual RotorWiki "Imagination costs nothing; we could build square locomotives or fly to Mars" - Felix Wankel Yesterday is history, tomorrow is a mystery, but today is a gift. That is why it is called the "present." | |
|  06-02-2011, 11:48 AM | #18 |
| Rotary Fanatic Join Date: Feb 2008 Location: Slidell, LA
				Rep Power: 18  |
			Yes Peter I agree that it would take three revolutions of the eccentric shaft to have all faces of the rotor see fire.  Following that logic the other trochoid shapes would need four or five revolutions to show all faces and hence we would have to multiply them by 4 or 5. I am saying that in all of these shapes that the displacement is the volume of the largest cavity created by the two corresponding surfaces (actually 4 counting end plates). This would hold true for a two-stroke and a four-stroke also.  As an example the caliber of this revolver doesn't change if it holds different numbers of slugs. It is still a 357.   |
|  06-02-2011, 04:26 PM | #19 |
| Don Mega Join Date: Dec 2008 Location: Utopia
				Rep Power: 18  |
			Barry, ALL of the total sum faces fire once in 1080 degree's, nothing more nothing less. Like I tell my students, you need to take time out and see the pictures, if you don't get it at first do not worry you are not the first and not the last to get confused on how internal combustion engines work. 2 stroke 4 stroke Wankel Its pretty simple really.
				__________________ www.riceracing.com.au Worlds best Apex Seals Coil on Plug Water Injection ECU Calibration |
|  06-02-2011, 04:32 PM | #20 |
				Rep Power: 18  |
			For EVERYONE remember this. In 360 deg ALL CYLINDERS in a 2 stoke fire once! no matter if its single or a V16! In 720 deg ALL CYLINDERS in a 4 stroke fire once! no matter if its a single or a V16! In 1080 deg ALL faces of a rotary wankel fire once! no matter if its a single rotor or a 4+ rotor! Which ever formula you decide to use in your PISTON applications you need to know which EQUIVALENCE displacement to use (2 stroke, 4 stroke or wankel) there are no aftermarket ECU's set up to run the true Wankel cycle or count the individual rotor faces based of its ACTUAL cycle (which is only 1080deg, nothing less)......... so you just need to know how a motor works and apply the other piston engine formulas to the wankel as appropriate (as I showed all of you)
|  06-02-2011, 05:28 PM | #21 |
| Rotary Fan in Training Join Date: Aug 2010
				Rep Power: 16  |
			Peter, I was curious about something. Would there be any benefit in engine control with ECU of such abilities? Like better fueling of individual chambers?
|  06-02-2011, 05:41 PM | #22 | |
				Rep Power: 18  | Quote:
  Yes there are major benefits! Mazda racing ECU's and stock ECU's are of this type 1080 deg true Wankel cycle, it is the only way to truely look at the engine. Otherwise you do need to do alot of conversions to adapt all the other ECU's, not to hard to do, but most dont get it, especially when you are looking at things like control of injector opening and closing degree's etc.
				__________________ www.riceracing.com.au Worlds best Apex Seals Coil on Plug Water Injection ECU Calibration | |
|  06-02-2011, 09:04 PM | #23 | |
 example (4) would take 1800º to complete all faces of its trochoid shape. Different rotor/stationary gear ratios would be used to accommodate the 4 in 3 and 5 in 4 trochoid mesh. Barry   | |
|  06-02-2011, 10:39 PM | #24 |
				Rep Power: 18  |
			I am ONLY refering to the Wankel Rotary I pictured and as we all use, drive and modify   Nothing else
|  06-03-2011, 12:39 AM | #25 | ||
| Rotary Fan in Training Join Date: Mar 2008 Location: Culver City, CA
				Rep Power: 18  |
			Interesting question, Barry.  Quote:
 In a similar fashion, you could compare a 1.3L two stroke piston engine to a 2.6L four-stroke piston engine... both ingest the same amount of air in 720 degrees, but the 1.3L two-stroke occupies less space and will weigh less assuming similar materials are used to build both engines. Is this starting to sound familiar? If I'm not mistaken, the two-stroke should have less torque at low RPM greater fuel consumption than the four-stroke. I'm not an engine expert (rotary or piston) so please correct this if I'm wrong.
				__________________ Quote:
|  06-03-2011, 12:48 AM | #26 | |
   You may not know where each individual rotor face is but that is not an issue so far as knowing the actuall Wankel Cycle and when to trigger things.
|  06-03-2011, 07:38 AM | #27 |
| Still Building my FD Join Date: Jun 2009 Location: Pasco, WA
				Rep Power: 17  |
			Guys, displacement by definition is the volume displaced by one revolution of the crankshaft or e-shaft in this case.  doesn't matter if it is 2 stroke, 4 stroke, or not. You guys are all going off on this "when does it ignite, and when does it do this or that?" It's all moot. total volume displaced over 1 crankshaft revolution = Displacement. It is consistent across the board. There is no Mazda conspiracy to hide its actual displacement. A 6.0 liter engine is a 6.0 liter engine, whether its 2 stroke or 4. You can't use the "Getting back to face 1" argument due to the trochoidal nature and the 3:1 ratio. If you do use this argument, then you have to divide the final result by 3 because of the 3:1 ratio. Now, what is the one consistent thing in all the engines? output RPM. Displacement is based on 1 of these revolutions. So any other attempt to define definition by more than 1 revolution is incorrect. 1 revolution is the consistent factor across the board. Te reason racing bodies use a multiplier is to even the playing field just like they do for 2-stroke engines. The advantage a 2 stroke has is that is happens to fire its full displacement per revolution, just as a rotary does, where as a 4 stroke only fires half of its displacement per revolution. Don't confuse revolutions of the rotor versus the crank/eshaft. You'll end up chasing ghosts.
				__________________ Uh.... hi. |
|  06-03-2011, 05:25 PM | #28 |
				Rep Power: 18  |
			It's not a  argument, its FACT! ALL INTERNAL COMBUSTION ENGINES (except the rotary!) are rated on ONE CYCLE OF WORK FOR THE COMPLETE ENGINE. Mazda conveniently choose to not rate the whole engine, if you or others can't get that then you need to move onto another area of interest I suggest, one you can understand   The Wankel Rotary is a 1080deg cycle, nothing more nothing less! You btw f*** your own argument cause a 4 stoke is NOT rated after only 360 degrees! cause it HAS NOT COMPLETED ITS CYCLE OF OPERATION! it is rated ONLY AFTER 720 degree's (suck sqeeze bang blow) it only SUCKS once in 720 degree's! and ALL piston faces are counted to rate the displacement of the whole engine! not 1/3rd of them, or 2/3rd's of them! but ALL OF THEM!......... The irony is only in the rotary world where people want to only count 1/3rd of the combustion faces and rate it as a 2 stroke engine, but its NOT! its a wankel and thus they only want to count one face (which misses out 2/3rds of the rest of the engine). if only you could do this on a BDC built half bridge!!!! then when it drops an apex seal on each rotor he can then tell you its only a 2 stroke engine like people in this thread and the other 2 apex seals and four combustion faces are not required LOL!!!!!!!!!!!
				__________________ www.riceracing.com.au Worlds best Apex Seals Coil on Plug Water Injection ECU Calibration Last edited by Barry Bordes; 06-04-2011 at 01:12 PM. Reason: foul language |
|  06-03-2011, 06:00 PM | #29 | |
| Rotary Fanatic Join Date: Mar 2008
 you are wrong though, piston engines suck all the time  mike | |
|  06-03-2011, 06:16 PM | #30 |
				Rep Power: 18  |
			Just remember Each engine is only *honestly* rated for displacement AFTER (ALL OF ITS ELEMENTS) have completed one cycle of work. Elements = ALL individual combustion faces Cycle = defined by power pulse (or simply spark firing) *remember suck sqeeze bang blow* It's not a hard concept to fathom honestly ......... some always struggle cause they don't know how the 2 storke or 4 stroke or Wankel actually work though! Define the cycle! Count the faces! There is your answer for displacement! Equivalence (like I mentioned in my second post) can be used to compare the 13B to other non wankel cycles (as defined by time to displacement), IE displaces 1308cc in 360deg or 2616cc in 720deg, but it only does its wankel cycle in 1080deg which my friends = 3924cc in 13B form, nothing less!
