Old 03-06-2010, 12:09 AM   #31
dudemaaan
dudemaaan's Avatar
Oh I didn't know you were suggesting the turbine outlet of the SmallT would be dumping into the the LargeT. That would work fine then, the velocity would still be high enough to spool the LargeT. You do realize the compound turbos have wastgates too right? They are plumbed in the same manor you're talking about. Sounds like there is really no difference in operation for the exhaust side of what you're suggesting. And in both cases you still run into the problem of two exhaust housings/wheels in the stream of the exhaust which will increase back pressure/EGT, especially if the first is a small housing to help spool.
The only difference I see now, is the cold side. In a compound turbo the LargeT cold side feeds into the inlet (where the air filter goes) of the SmallT. This is where the compounding takes place. The boost is "compounded" or multiplied. While in a sequential system, there is usually a butterfly valve to keep the turbo that's "working", flowing only into the manifold, then the butterfly opens and allows the second turbo to contribute to the total volume of air, but it in itself would not increase boost pressure. The difference is much like the following diagram of 2 pumps in series vs parallel. Series would be compounding, and parallel would be sequential.
Here you can see the wastegate in the image below of a compound turbo.
