#31 |
IT'S ALIVE!
So I went out and fiddled with things again; this time I took some video. I don't know how to embed these so direct links will have to suffice.
First, here's the behavior when cold: https://picasaweb.google.com/lh/phot...eat=directlink Next, fully warmed up: https://picasaweb.google.com/lh/phot...eat=directlink Last, here's after revving the piss out of the engine. Notice the coolant level: https://picasaweb.google.com/lh/phot...eat=directlink Just for giggles, I think I may have found an exhaust leak. Yes, I know I should not be revving the engine like this: https://picasaweb.google.com/lh/phot...eat=directlink |
#32 |
Rep Power: 20 ![]() |
I don't know... It really seems like a fire ring has decided to let go.
#33 |
IT'S ALIVE!
Yeah, it wasn't too happy starting this morning. Basically, I've already started looking for engine stands, hoists and other tools needed to pull the engine. Likely going to start the teardown this weekend.
#34 |
Ouch, after looking at the videos, I have to agree it looks like a teardown is needed.
#35 |
Mazda Lover
I wish i had time this weekend to come down, I have an engine hoist i could bring with me.
![]() 2004 Mazda6 V6 5-spd - still waiting on money for a motor 1991 Mazda RX7 NA 5-spd - my new DD with 145,000 miles |
#36 |
IT'S ALIVE!
Well any doubts the engine is fried have now been eliminated. Started the car after work and even though it started right up it sounded like it was only running on one rotor. Eventually the engine caught itself and I was able to drive home. Got home, shut it down and changed, came out to start it to depressurize the fuel system and it absolutely would not start. It took me 30 minutes to start it again and the same thing happened - started on one rotor but after a few revs and about 30 seconds the second rotor kicked in. Pulled the fuel pump connection and let it stall out and started the teardown. Can't wait to see what exactly happened.
Last edited by infernosg; 05-03-2011 at 07:00 AM. Reason: cylinder, rotor - same difference |
#37 |
IT'S ALIVE!
Started the teardown last night. Found something interesting. Note the line for the oil injector on the primary port for the front rotor. That couldn't've been good for the engine!
#38 |
Eh, that's not as bad as it could be. I'd be a little more concerned if the primary oil line was broken (the one that sits directly on the rotor housing).
#39 |
Mazda Lover
well do you premix?
#40 | |
IT'S ALIVE!
Nope, never saw a reason as the engine was stock and I assumed the oil injection system was working just fine. |
#41 | ||
#42 |
IT'S ALIVE!
Starting pulling the engine apart and found some more interesting things. Notice all the oil buildup. I think there was something seriously wrong with the front rotor/housing/iron - this thing is nasty.
![]() Here's a picture of the auxilliary port sleeve for the front rotor (far upper right port in the previous picture). Again, note the oil buildup. ![]() Now here's the rear sleeve. Notice how this one is basically spotless but there may be a reason for that. When I tried to turn the actuators the drive the sleeves I could not get the rear to move AT ALL. It doesn't seem like it has moved in a while. ![]() Now some spark plugs. First picture is the front rotor and the second is the rear. It may be hard to see but the plugs for the first rotor are noticeably "wet" while the plugs for the rear rotor are dry. Looks like oil to me. ![]()
#43 | |||
![]() Quote:
#44 | |
#45 | ||
IT'S ALIVE!
You know what I meant! This is my first rotary so I'm still used to diagnosing issues in piston-engine-speak. |
