Old 01-28-2010, 02:47 PM   #16
reddozen
Gold Wheels FTW
reddozen's Avatar
Originally Posted by RE_guru View Post
ur right i would test ur parts first but speaking of renisis swaps my fiance's miata will be getting one. she originally wanted a '99 FD engine with the twins but in a 2300lb miata i think that with a intercooler and power FC would be too much. I am thinking a bone stock renisis with the 6spd would be perfect in that car i have already started measuring.
If you're going to do all that, then I would recommend an 09+ engine / trans swap. Should hold up better anyway. I just already have an extra 04~08 engine, so that's the only reason I'm, not buying an 09 to do the transplant.
My Cars:
1974 RX4 Coupe
1991 FC3S RX7 - Sold
Old 01-29-2010, 12:12 AM   #17
MAZDAT
MAZDAT's Avatar
MAZDAT is on a distinguished road
Hi everyone!!!
Hi, I'm new to Rotary Car Club, looking foward to talking to you guys
MAZDAT is offline   Reply With Quote
Old 01-29-2010, 02:21 AM   #18
RE_guru
RE_guru's Avatar
RE_guru is on a distinguished road
i would but i will probably get a front clip off a totalled car so i have all the parts i will need i will essentially put it in using the drive by wire and the cluster to save money nothing fancy.
'94 Mazda Rx-7 montego blue
'88 Mazda Rx-7 se (SOLD)
'04 Mazda Rx-8 GT 6spd (daily)
Control Freaks www.cfdrift.com
All Your apex R belongs to US!
RE_guru is offline   Reply With Quote
Old 01-29-2010, 11:49 AM   #19
reddozen
Gold Wheels FTW
reddozen's Avatar
That's cool. I've been trying to figure out how I'm going to put it in the 7... I don't think it can run the factory RX7 gauge cluster, so I may have to do something similar to you and use the cluster and everything. yay for custom fiberglass work...
My Cars:
1974 RX4 Coupe
Old 01-29-2010, 02:12 PM   #20
RE_guru
RE_guru's Avatar
i have a friend that is great with fiberglass and will probably have him finish the dash out once i get it all mounted but tha project is a ways off i have to get my FC done.
Old 01-31-2010, 04:18 PM   #21
RE_guru
RE_guru's Avatar
picked this up from an imported here in St. Louis it was a little scratched up so i had the bar repowdered in "wet red" and the mounting plates in "wet black"
Old 02-02-2010, 04:02 AM   #22
RE_guru
RE_guru's Avatar
might be a little TOO tight.
Old 02-02-2010, 09:19 AM   #23
3tegStrong
XRANNIE
3tegStrong's Avatar
3tegStrong is on a distinguished road
howdy & welcome!
got peter?
GO NAVY..Thanks to All who've served!!!!
http://www.theautolog.com/3tegstrong-1
3tegStrong is offline   Reply With Quote
Old 02-03-2010, 10:37 AM   #24
rotor85
rotor85's Avatar
rotor85 is on a distinguished road
thanks
no, currently the GT-K is not configurable so u have to buy one off the shelf with what ever specs they make. I custom ordered mine it is a turbonetics 62-1 with a .81 ar ratio and ceramic ball bearings. if i had bought the standard 62-1 it would have be a 1.10 ar ratio.
I got the same turbo in my fb. its not the BB though and yet it spools up hard by 4000 to the point that the rear kicks out in a straight line drift!! u gotta love that solid diff in the fb! i can only imagine with the BB it spool sup even faster then!!
rotor85 is offline   Reply With Quote
Old 02-04-2010, 02:30 AM   #25
RE_guru
RE_guru's Avatar
yeah and since i downsized the ar ratio i build boost anywhere above idle and am at full boost at 3000rpm
