Rep Power: 17 ![]() |
Need your knowledge.
I have no idea where or what to do . I have no boost reading .please help tk Where i should connect these lines.
Another thing when i press the gas to go fast the car starts to miss fire please any one with the knowledge help... |
Rep Power: 22 ![]() |
Boost leak somewhere most likely.
The first pic is nothing, I have the same uncapped pipe there. The second pic, I don't know what you are trying to show, but it looks like you need to have that vacuum hose going to the boost sensor (stock ECU??) teed off to the wastegate/boost gauge. The third pic looks like the same style plug as an injector, but I don't know why it is down there. I can see behind it though that the ground tab is not connected. That isn't good at all.
#3 | |
I will put some up after work. So after 5pm CST.
As long as your is S5 with no emissions, it should be similar.
In the third pic, I think that might be the plug that connects to the oil level sensor on the oil pan, or maybe it connects to the transmission wiring?
do you have a hose clamped to a hose?? .... boost leak
OK, same order as your original pics-
#1- Rats nest lines to nowhere. #2- Diagram of how I have my boost goodies set up. ![]() #3- That is for the oil level sensor. Could not get a good pic since mine is covered in crud, and the flash didn't help, but here it is.
#9 |
AWWW, someone learned basic photoshop....
![]() and is that rust on the tip of your blow valve? ![]() lol
#10 |
Yes. That fucking car cover kept all the moisture UNDER it!!
Piece of crap.
#11 |
#12 |
his motor has no emissions... you need to find you an emissions diagram and your search will end
#13 |
#14 |
If you are going emission delete........you basically block EVERYTHING except for a select few.
-Leave the large port on the backside of the TB for the Oil Injector Vacuum spider (unless you are pre-mixing, then cap it) -Leave the large port for the brake booster -Leave the port on the turbo side of the UIM (pictured above) for boost reference -Leave the port for the Fuel Pressure regulator. Everything else is capped off. That is really all you should have if you are emission free.
#15 | |
![]() Quote:
can i call you or you call me 239-281-9768 michael
