Go Back   Rotary Car Club > Vendors and Group Buys > Group Buys
Old 01-07-2015, 08:37 AM   #61
infernosg
IT'S ALIVE!
infernosg's Avatar
I'm paying attention. Chris (Ludwig) knows a setup like this would benefit me. It's too bad the Series 4/5 center housings don't have that little bolt hole though. Using the knock sensor hole isn't a bad idea for those using a cheaper engine management system like me.
Old 01-07-2015, 08:37 AM   #62
C. Ludwig
Rotary Masochist
That's 90*. I said 180*. . In the original version the long side of the coil is facing forward. Flip it so the long side is toward the back. My guess is it still won't provide enough room for the AC compressor. I tried this a couple years ago. It's tight in there!
http://www.lms-efi.com
chris@lms-efi.com
502-515-7482
Facebook @LMS-EFI
Old 01-07-2015, 09:04 AM   #63
RICE RACING
Don Mega
RICE RACING's Avatar
You end up with some interference between the coil tabs in one orientation and in the other (offset) I'll need the bevel one edge of each coil spacer mount ..........
See what I can come up with, this way will clear as best it can and not interfere with heater coolant pipe as well, otherwise I would have spun it other way!
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-07-2015, 09:15 AM   #64
RICE RACING
Don Mega
And this way the coils smash into each other and there is ZERO room for a mount on the center plate...........
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-07-2015, 09:21 AM   #65
RICE RACING
Don Mega
Not possible to fit a proper mount in ~6mm space (plate + fastener).... well I would not feel good about it, I could recess something in not a worry I suppose, but add to that you will need to file down the tabs on the IGN-1A's as well as there is interference there too.
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-07-2015, 09:28 AM   #66
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Looks awesome Peter!! Count me as down for the compact V2, adapter and mounts =)
'94 Touring - Cursed
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 01-07-2015, 09:54 AM   #67
infernosg
IT'S ALIVE!
infernosg's Avatar
I'd be interested in just the COP adapters. I have a Series 4 center plate without the center mounting point so the interference isn't really a problem. I'm sure I could come up with something that uses the knock sensor locations.
Old 01-07-2015, 01:02 PM   #68
So it's confirmed that the PS and AC pumps would be in the way of this on the REW?
Old 01-07-2015, 07:06 PM   #69
RICE RACING
Don Mega
I don't think anyone has validated that yet?
I do have all those systems stored away, if I get time will pull them out and mount to front plate and have a look physically at the potential interference
These coils are shit for fitment, so looks like V2 system is for people who are willing to move shit around to suit or run a car that is more 'race spec'
ONLY thing I can do to try to suit (well at least a 13B-REW rotor housing) is go for a knock sensor based central mounting method, this means can use the system on 1,2,3,4,5,6................. 25 rotor applications with ease, Will stack these coils 'vertically' and come up with a system like that, I think I will do the same with the M&W CDI coil as well, however! its got its own issues.
p.s. That shit wont work, I can run an analysis on it but will have to run a 'stupid' size mounting system as there is a big canter lever effect from that fixed point, would be vastly more complex as well I wont totally dismiss it, but my brain is telling me its going to be an abortion.
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-07-2015, 07:47 PM   #70
RICE RACING
Don Mega
I have thought of EVERY permutation and the below is the ONLY one that is viable, need some input if people are interested in me developing it?
Involves cutting off one of the tabs on all four coils (simply at the edge of the sleeve), then it will allow placement as per below and clear everything.
The coil bracket spacers will be 154mm long between centers and obviously new (13B-REW) engine bracket required.
I'll start fucking around with it anyway to show what I am thinking and that way you can decide if its what you want.
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-07-2015, 09:39 PM   #71
RICE RACING
Don Mega
Working on V3 (vertical placement)
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-07-2015, 10:18 PM   #72
Oh OK. The reason I said that was because Monkman was talking about making brackets to make it work for him, so I assumed it didn't fit. I'm certainly not asking YOU to do it, not after all the work you've put in already. If I was home I'd check on it myself. Honestly I like V2 the best. I doubt it will ever get more compact and optimized than that. I honestly think it would work with the AC and PS too, but maybe not. I'm not home to look at it. I'm planning on using dual knock sensors so I wouldn't get that one anyway, even if you did make it. So if V2 doesn't fit, oh well. I guess I'll have to pass. I'm hoping it does though.
Old 01-07-2015, 10:40 PM   #73
Curious about placing things vertically
Old 01-07-2015, 10:41 PM   #74
It looks fucking killer though Peter
Old 01-07-2015, 10:44 PM   #75
chibikougan
chibikougan's Avatar
Will make room on the 2
