Rotating Assembly
Boost falling off
Relevant mods
90 S5 Vert.With the EVC off, we were seeing a max of about 4.5psi so I'm assuming the wastegate spring is about 4.5pounds. We set the EVC to 50% and we were expecting about 7psi max (4.5 + (50% * 4.5)) but it went to ten; which was fine. As you can see in the Zeitronix chart, boost is maxing out at ~10psi at 4700RPM and drops off gently from there. ![]() We are using Aaron Cake's rule of thumb AFR tuning targets 0-4 PSI: 12-12.5but obviously the 1000cc secondaries still need to be pulled back some. IIRC we are pulling them back about 3% above 4500RPM. Is the fact that we're getting too rich after 4500RPM what's causing the boost to fall off or is the wastegate spring at fault? Thanks, appreciate any guidance yall have.
![]() ![]() 90 S5 Vert. JDM Tii with BNR Stage1 turbo. Pineapple Racing street port. Bonez cat-forward. Corksport cat-back with Vibrant UltraQuiet resonator. RTek 2 wZeitronix w/b. HKS EBC. Vis CF Tii hood. 3000GT wing. Ground Control coilover kit with KYB AGX shocks. Red and Black leather RX8 seats. Corksport Odura lip & bumper caps, OEM Tii skirts |
