Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Rotaryshack
Rotaryshack www.rotaryshack.com (CA) Specializing in carbs, custom turbo kits, 1gen rx7 parts
Old 09-23-2008, 08:34 AM   #1
About the T5 adapter.
The T5 adapter is only good for the Ford splines im guessing, but the options i have found for the T5 make interested in the GM transmissions. Namely what i can get with my choice of gearing. I want to get as close as possible to the Mazda Comp. transmission ratios, which Richmond sells for the Super T10. But it looks to be only the GM 1-1/8" 26 spline. Do you know how different the GM transmission is? I might need to discuss in another thread about gear choices because there are some T5 options that may or may not work, since they are using 5th gear as 1:1 and sadly, are more money...
as per the listing
T5 mustang transmission to mazda transmission bellhousing adapter.
This adapter will enable you to bolt up any T5 transmission to your mazda
bellhousing ! Includes mounting hardware, no more broken trannys!!
Price $550.00
Old 09-23-2008, 09:04 AM   #2
730RWHP12A
as per the listing
i will talk to my machinist and see what he can do. im sure if you if you need one for the super 10 i could just make you one
rotaryshack.com
Old 09-23-2008, 09:27 AM   #3
i would love you long time
Old 11-22-2008, 12:14 PM   #4
Boxcar
Boxcar is on a distinguished road
Could someone please point me to a thread where this product was discussed or post a product link? I have all kinds of questions. Which transmissions, gearing, which clutches will work, is it track legal, etc. Thanks!
1990 RX7 Vert, very large ports, GT4094R, SMC Alcohol Injection, Haltech E8
498WHP @18PSI on 91oct/pump gas
541WHP / 418FT-LB @23PSI on Q16
Engine built by Arizona Rotary Rockets
Boxcar is offline   Reply With Quote
Old 11-22-2008, 12:19 PM   #5
there is an FAQ in the transmission / diff. section with links and information that should help
Old 11-27-2008, 03:28 PM   #6
730RWHP12A
you can get a wide combo of gear ratios for a t5 tranny, you can even make it a clutchless unit if you want. the clutch would be a mazda pressure plate with a custom clutch disk that has the t5 input splines. as far as it being track legal, what type of racing do you do? what is the sanctioning body?
rotaryshack.com
