Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Rotaryshack
Rotaryshack www.rotaryshack.com (CA) Specializing in carbs, custom turbo kits, 1gen rx7 parts
Old 09-23-2008, 08:34 AM   #1
About the T5 adapter.
The T5 adapter is only good for the Ford splines im guessing, but the options i have found for the T5 make interested in the GM transmissions. Namely what i can get with my choice of gearing. I want to get as close as possible to the Mazda Comp. transmission ratios, which Richmond sells for the Super T10. But it looks to be only the GM 1-1/8" 26 spline. Do you know how different the GM transmission is? I might need to discuss in another thread about gear choices because there are some T5 options that may or may not work, since they are using 5th gear as 1:1 and sadly, are more money...
as per the listing
T5 mustang transmission to mazda transmission bellhousing adapter.
This adapter will enable you to bolt up any T5 transmission to your mazda
bellhousing ! Includes mounting hardware, no more broken trannys!!
Price $550.00
