Old 03-29-2011, 11:05 AM   #8
MmSadda
BOOSTED COLON
MmSadda's Avatar
MmSadda is on a distinguished road
Originally Posted by RXTASY View Post
Pull the plug wires and put a screw driver to the tip of them and see if there is a spark arcing.
If there is, pull your two leading plugs, and yer EGI fuse and turn it over and blow all the gas out of it. Squirt a little motor oil in there while yer at it.
Try that.
As in, screwdriver in one hand, and one plug wire end in the other, right? how far apart should I hold them?
If there's no spark arcing, that means my trailing coil is not functioning, then, right?
MmSadda is offline
