-   -   Recently rebuilt 2nd gen suddenly won't start - where to begin? (https://rotarycarclub.com/showthread.php?t=13765)
MmSadda 03-28-2011 11:20 PM
Okay, here's the deal -
I'm driving an S4 (87) n/a, stock for all practical purposes, got about 25k miles on a rebuilt engine, and at the same time got new fuel pump, new injectors, new ignition coils, etc.
I drove the car two days ago, and it ran 100% normal. Tried to start it today, and it'll sit there and crank and crank but won't actually fire up so I think I'm either not getting fuel or not getting a spark.
What's a good starting point as far as things to test?
**I should note, the guy who rebuilt my engine installed a kill switch (pretty sure it's for the fuel injectors, in case the engine floods)
tweiss3 03-29-2011 06:35 AM
Did you try "flood" starting it, put the pedal in the floor and crank it? See if it turns over then.
RETed 03-29-2011 06:50 AM
This does not work for any S4 vehicle.
tweiss3 03-29-2011 07:03 AM
Oops, works on my S5. I forgot. Pull the plugs and crank for 15 seconds, reinstall plugs and see if it starts up.
djmtsu 03-29-2011 08:13 AM
Shouldn't the tach 'bounce' if it is getting spark?
I forget.
vex 03-29-2011 08:27 AM
I forget.
Yes, but that only indicates a specific coil is firing.
RXTASY 03-29-2011 10:52 AM
Pull the plug wires and put a screw driver to the tip of them and see if there is a spark arcing.
If there is, pull your two leading plugs, and yer EGI fuse and turn it over and blow all the gas out of it. Squirt a little motor oil in there while yer at it.
Try that.
MmSadda 03-29-2011 10:52 AM
Thanks for jumping in here!
What will that do? If it's a cure for flooding, the kill switch works for that. If it's supposed to cute something else, lemme know and I'll try it!
I forget.
My tach 'bounced' all of once in the whole time I was trying... so it does sound like I may not be getting spark. What would I do to test/confirm this?
MmSadda 03-29-2011 11:05 AM
Try that.
As in, screwdriver in one hand, and one plug wire end in the other, right? how far apart should I hold them?
If there's no spark arcing, that means my trailing coil is not functioning, then, right?
FC Zach 03-29-2011 11:20 AM
I typically just leave a plug in the end of the wire and ground it, have a helping hand to turn it over, and while that is going on you can observe whether or not there is spark. Screwdriver works too, just a little cumbersome to me.
Redshft 03-29-2011 11:58 AM
This.
But, having been zapped before, I'm now paranoid and I use a set of pliers with an insulated handle to hold the plug by the boot on the wire.
FRED 03-29-2011 12:19 PM
Watch the tach needle while trying to start the engine. IF the needle makes small movements that tells you a lot. It tells you that the ENGINE fuse, both EGI fuse are all good and that the main relay is pulling in.
Engine will not start with a blown EGI fuse(s), engine fuse, period.
IF the needle does make movements try deflooding it by the usual methods. I assume you don't have a blown apex seal when saying this and you have gas in the tank and there is no fuel cut switch in the OFF position.
EDIT: And or ...........put a jumper in the fuel pump check connector and the key put to ON. The fuel pump should be heard running. If not.......too bad, something is amiss.
My5ABaby 03-29-2011 12:50 PM
Pulling the fuse does essentially the same thing your fuel cut switch does. Putting oil in the engine helps build compression if it's been flooded.
MmSadda 03-29-2011 12:52 PM
I'll check the EGI fuse. -checked and all fuses with EGI in the title are fine.
Tach is making the tiniest of bounces once each time I start the ignition, then nothing.
**engine isn't flooded, there's practically no way an apex seal is blown, etc. - Fred's assumptions are all fair.
MmSadda 03-29-2011 12:53 PM
Where is the fuel pump check connector? Not coming up with that one easily in the Haynes manual
