You check the TNS relay?
Providing rotary engine rebuilds, porting, turbo installs, parts installations, full maintenance, etc. We work on all cars. www.irperformance.com www.myspace.com/rotaryexperimentseven irperformance@live.com 732-662-1794 |
will do this weekend. I have been so busy and then I got sick that I haven't had time to work on it.
I replaced all the fuses that had issues - door locks, brake lights..nothing worked. the guages are disconnected until I get the rest of it fixed. I see where the clutch pedal wore through the wires. stupid me, being stupid lazy. Does the TNS relay affect the door locks, radio, turn signals and brake lights? How much is a TNS relay?
This is going to tear |
Replaced the TNS - no luck. Turn signal makes sound, but not lights on dash or on outside of car.
turned out to be the BTN fuse in the engine bay. Electrical manual didn't say to check so I overlooked it. Spent a good part of the day rerouting the harness with a buddy. Much much better.
The aftermarket gauges work, but won't change display when the headlights are on. We checked and its getting voltage on the harness, so something is messed up inside--later it randomly switched displays. Good to have it driveable again---life lesson 13423589097234--route better 1st time lazy ass.
