#12 | |
I think that if you keep the PP downshifted, your throttle response would be better than with the turbo. You will probably have to shift less frequently with the turbo. I think that a NA streetport would be fun on a hillclimb, mine makes pretty good torque from about 3,000 rpm to 9,000 rpm (good broad rpm range is better for racing as you are not always in the wrong gear). I sure hope I get those rotors changed before the snow flies. (It is not currently looking good).
